Iceman 0000
My note 2 normally charges at the speed of 22% per 30 minutes till 90%.. but charges slowly after 90%...and it takes more than 30 minutes to charge from 99 % to 100%... please help
I have read about this type of issue on several different occasions with different devices. It is always difficult to diagnose.
1. Are you using the original supplied charger with the device. My wife's Note II charges fine with our old Moto chargers, but I have heard of off brand chargers being the problem.
2. Try rebooting the phone. This is probably the first thing that you tried, but some folks wouldn't turn their phone off to save their own children, so I had to mention it.
3. The next thing to try is to reset the Dalvik cache on the phone. You will find the menu to clear the Dalvik cache in the same menu where you can hard reset the phone.
4. Try a hard reset. I know it is a pain in the behind, but worth a try, if non of the above does any good.
5. Take it back to the store and get it exchanged. Sometimes the circuitry that does the charging goes bad.
I have heard of all of the above working in various different instances of bad phone charging. Nothing above, except the hard reset and exchanging the phone, cause you to have to re-do everything. The Dalvik cache thing will cause the phone to be slow or sluggish for a day or so.
Good luck and let us know what if any of the above helped.
BigRedGonzo
My phone sort of does the same thing. It will stay in the upper 90's for a little longer than lower percentages as if the charging slows down.
I don't really see this as an issue, though. The battery takes maybe 2-3 hours to fully charge, and my battery life seems normal. So I don't really care what the battery percentage indicator is doing during charging.
I wouldn't be too worried, I don't believe that there's any issue or problem with the battery, phone, os.....
