Got this one in today:
LOVE MEI smoked pull type metal bumper for GALAXY NOTE 3 - Love mei
All cut-outs are precise,volume rocker & power button both work very well,just the perfect amount of tension for ease of use w/o the sponginess for accidental pressing while pocketed/holstered/etc.....
As for feel-in-hand,all cases I've used push this to the edge,as the phone is large enough w/o a case,so,I can't be the judge as to how this would be for someone else.
The finish is flawless (GLOSS BLACK),however,I'm considering using the sand/bead blaster @ work to give it more of a matte finish/rougher texture,for a better,more secure feel-in-hand.
As for compatibility/fit,works w/the standard battery cover,as well as the QI-ENABLED OEM SAMSUNG Battery cover.However,it does not fit on extended battery covers for the HYPERION or ANKER 6400 Extended battery,due to the lack of contour/radius on the top & bottom of the extended battery cover.
As for protection,this is a bumper-only case,providing edge-only protection.There is ample protection on the front face of the bumper for screen protection when the phone is placed face-down on a surface.
I recommend this case,but,definitely look around for better pricing (e-Bay/AMAZON/MOBILE FUN.etc)......
Is that the one with the sliding top that secures the device inside?
They have different 'Love Mei' versions at the eBay UK link here, including the slider one, plus ones that secure with two small grommet screws in one corner. Way cheaper than $58 too.
SOLID ALUMINIUM METAL BUMPER CASE COVER FOR SAMSUNG GALAXY NOTE 3 N9000 N9005 | eBay
 Ebay.i decided to go with the Spigen Bounce cover, and received it today.
I gotta admit, it fits GREAT and is quite slim. i like it a lot more than i expected! 5*
They iBlason seems to fit your requirements IMHO. You can find cheaper unbranded versions as well on Amazon andEbay.
I thought you might like it.Who were you addressingthis to?
This one is close but no snap over closure;
Krusell Luna 4XL Mobile Leather Pouch for Samsung Galaxy Note / Note 2 / Note 3 (Black) at MobileCityOnline.com
