It can't be a speaker! It has bars on the other note3"s that I've seen.The circle with the line through it is a speaker, it looks as though you've silenced ringtones and notifications but its on vibrate.
Mm and what exactly does that mean....No signal
Sure here it is.Can you circle or highlight the icon you mean please?
Ok gotcha. Yes in my home it shows this. I don't always keep a eye on it. What would it effect if it's weak...thanks for ur help btw.That's your cellular signal strength. It looks as though it's pretty weak at the moment.
Its not a circle though?
Sometimes it does become a circle though.Ok gotcha. Yes in my home it shows this. I don't always keep a eye on it. What would it effect if it's weak...thanks for ur help btw.
I see gotcha! Thank you for explaining it to me. I was asking around and know one knew....No problem!
If it's weak, the obvious thing would be the potential to miss calls/texts etc. It will also have an impact on battery life. If your signal is weak the phone will push more power to its radio to help it get a better signal.
No idea about why it becomes a circle though, sorry.
Ok thank you...i will do that for now on.For similar questions, you can always check in "settings", "about phone", "icon glossary" for any and all symbols that will appear on your phone.
