Root Notification Icons
Bankswood
Android Expert
Now that GB is out (leak and OTA) does anyone know where I can get some cool icons for my notification bar? I used to use DroidPirate and load with MetaMorph but those don't work anymore.
Check out the UOT Kitchen on the net Bankswood. I use them and they still work for the 596. Put them along side of Bouchigo's mods and you have a pretty personalized phone.
NOTE: Always flash Bouchigo's mods FIRST! Then you can upload your systemui.apk and framworkres.apk files to make your own icons. If you flash your own icons before applying bouchigo's mods it will replace your new icons you just made at UOT.
