Notification light
I'm thinking that the amber or green led's would be easier to see, if the M8 was in black.:p
Would be easier to see if it actually worked and ESPECIALLY if it was bigger... Its the size of a pinhole
I just realized my LED notification light has not been working for a while now. Checked settings, rebooted. Still no go. Downloaded an LED notification tester called "LED Tester". Still no light when I put it to sleep on any of the different colors you can try. How do I tell if my LED is burned out?
It's got to be one of the apps that I carried over from my GS4, but then I should get a light when I restart it in safe mode, but no... Crazy! Maybe HTC will figure it out, I give up!! I still love the phone, and would take it without the light over any other phone. ;-)
Okay, the test shows that the lights are working! The question is still why don't they work as notification lights... Thanks for the tip on that app!
What's the name of the app.. I'll try it.. My LED light only work while charging... I've tried LED tester apps and nothing works
Wow! Cool app. My LED lights only flashed from red to green.. Is that it? Are there any other colors?
