Help notification lights
you can't...at least not all stock. If you want to change them for txt msgs ec. Chompsms from the android market is a pretty sweet app. Hope that helps
I would also suggest Handcent SMS, as it allows you to change it to any color. Along with that you can change everyother part of the program.
