Root Notification sound Problems
DSG04lightning
Well to start off i was stalling the update to 2.3.xxx but i decided to go ahead and install Apex rom. Well after installing Apex i realize the update was also installed. I kept trying to install the "goodies" Phone would not boot into clockwork and Rom manager would not "fix permissions" kept saying not enough permission. Looked online and found the solution to unroot and reroot with Z4 root. So at this point im rooted again. But now im having issues with the phone ringer only vibrating and not ringing no matter what i do. tried other solutions i found but nothing worked. Plus it seemed like all the problems were from when 2.2 froyo first came out. Any help is appricated
Sorry I couldn't help before. One question. Were you upgraded froyo 2.2.1 (at least 2.3.320) before you installed ApeX 1.3.1? You have to be or it won't work right, fyi.
That's it, then. You must sbf to 2.3.320 before you successfully use a rom based upon android 2.2.1 like apex 1.3.1.
Follow the directions in letter C "unBRICKING". After you've done that, root your phone then re-flash ApeX and your problems should go away.
http://androidforums.com/droid-x-al...ing-custom-rom-theme-how-unbrick-droid-x.html
I'll copy it below for you.
C. UnBRICKING INSTRUCTIONS:
HELP ME. Ima noob! I BRICKED MY PHONE!
1. go to Droid X: 2.3.32 Full SBF and DL the leaked full OTA FROYO 2.2.1 .SBF file.
2. Download and install RSDLite v4.8 (it should be on Home if not, go Google it.)
3. If your phone is stuck on the load screen, pull the battery, wait a minute, push the battery back in and restart with the phone’s Boot Loader Mode (do this by pressing the red camera button + volume down + power button  hold all of them in the order that I stated until your phone flashes briefly). Your phone should flash white and a Boot Loader menu will come up. Make sure there is at least 20 to 25 percent battery life remaining in order for the reformat of you phone to complete. If your phone dies in the middle of this process GOD HELP YOU.
4. Run the RSDLite File and connect your Droid X to your computer via USB.
5. Browse for the .SBF file you downloaded in step 1 and click “Start”, at which point the program should run and your phone will proceed to unbrick
6. EASY RIGHT?
7. Once unbricking you will have to go through reactivation of your phone. This is normal so just go through the steps you did when you first started.
8. GUESS WHAT? You made a backup of your previous customizations REMEMBER? If you don’t want to deal with the hassle of re-downloading your entire life onto your phone again follow the “ROOTING” instructions in Part A and redownload Bootstrap and reboot into recovery mode to RESTORE the backup you made by following steps 2-11 in Part B….except you won’t be going to “install from sdcard” you will going to “Backup and Restore” and “Restore from sdcard”.
