Nova Launcher
jds4000
Has anyone tried Nova Launcher on the GS 4 ? This launcher allows you to change the default grid on your device to one of your liking. Example. You can easily change to icon layout from 4 rows of 4, to 5 rows of 5, or whatever you choose. There are a host of other features.
Yep, I'm running in on my phone now. Much more flexibility than the default TouchWiz launcher.
I have had android for 3 days now and I downloaded Nova the first day I switched.. its amazing.. but I am wondering if Nova is the reason my phone seems to lag a lot.. or if the lag is because of something else..
Please refer to the thread regarding lag. There is a GREAT YouTube link showing a fix for screen lag on the GS4. There are several tricks that completely remove lag. Your device will run lightning fast. See the lag thread or do a a YouTube search. KEYWORDS FIX GALAXY S 4 SCREEN LAG. BTW Nova Launcher DOES NOT contribute to screen lag.
thank you I will check it out!
Yup! I even paid for the Nova Launcher Prime (worth it) for the other extra features. Been running this launcher since Galaxy S2. It's close to stock Android and super clean
I use apex and prefer it over nova (although not used nova for a while)
I think both seem very similar in look and what they do though.
I find it has more to offer, i like the latest feature of being able to create folders in the app drawer.
I bought the pro version of it, take a look:
Apex
I was using Apex Launcher but I recently switched to Nova Launcher. Apex has a lot of features but in some ways because it has so many features it has become bloated. Hopefully Nova Launcher doesn't go the same route.
I use Holo Launcher HD on mine. I had used all the major launchers about 6 months ago on my EVO LTE. I can't actually remember why I landed on Holo, instead of the others, honestly! :)
I tried TW for 2 days. I come from Sense (last 3 phones) so TW was pretty brutal. I've been running some form of "stock Android" launcher since I bought my wife her Nexus 7. I really like the vanilla Android.
Nova Launcher is good, But Apex seems better.
Best part what I like is full skins are available for apex, where Nova is just manual customizations, there is no all in one theme package for nova.
Apex Notifier is cool and available for free for Apex Pro users.
Quick question... do I have to be rooted to run Nova? I have the s2 skyrocket and wanna try it out on this one before I put it on my new s4 this weekend...
