now that I'm rooted and flashed...
dierna
I rooted my T989, and flashed Infamous Resurrection, which I like so far. A couple of questions though...
There's an icon at the top that says "wi-fi calling error ER05 invalid SIM card". I can make telephone calls just fine. My network doesn't support wi-fi calling as far as I know. Is there a way to dismiss the notification?
Also, I've downloaded most of my favourite apps from the Play store, but oddly, my phone doesn't show up at all when I go to the "my apps" tab on my PC. I do often install apps via my PC - is there a way to get it back on there?
I'm sure I'll have other questions...
Look in settings > wireless and networks and see if wifi calling is checked. If it is, uncheck and see if that fixes it.
So you can download from your phone ok? Can you download an app from your pc or does your phone not show up in the drop down list? Try going to my account > settings. In the list of devices, does your phone show up there?
Odd, my phone wasn't showing up in Play last night, but it is there now.
And yes, disabling wi-fi calling did the trick. I guess the default in this ROM is to enable it.
