Root odd problem with car charger
This may need to go to ROOT section..
I am rooted
Mikg sense 3.0
chopsuey
set cpu installed and overclocked to 1075200
OK...
1 during charge using cigarette lighter plug my Navigation will screen off back to my home screen where my icon is located, however, Navigation is still running in background. Audio turn by turn still working and program shown in navigation bar.
2. Used Car Home (car panel) and same thing. Screen goes off and back to home scree with car panel icon. Contacts will also open then close.
Navigation will run for 4 - 6 minutes on charge.
I've changed chargers. 1 is sprint cable, the other is sprint usb with aftermarket lighter adapter.
no problem off charger.
I'm also running setcpu and tried changing some settings. Doesnt seem to matter.
That's odd. Maybe the charger is hitting a pin in your micro usb port just the right way and it's kicking you out of navigation for some reason? Is it some cheap generic charger? I bought a cheap one at walmart and don't like the way it fits into my charge port so I never use it because I don't want to mess up the pins.
Hopefully your not getting a pin problem. My phone used to boot into carmode and you couldnt get out of it. Really sucked having every phone call you make default to speakerphone
Check out what the others have suggested, and then check your pins where the phone plugs in, remove any dirt ect that may be causing issues
