PhoneMan93
Why is it that every time i use Odin i either get Google Auth error or Connection issues, I'm just trying to Odin the Stock ROM's so my trick doesn't work can anyone please help me? Thanks.
if you are coming from an ext4 based ROM like CTMod or CyanogenMOD
make sure you convert your cache partition back to RFS
you have to flash this file in CWM
Hmmm.... I just went to CTMod... might need to use Odin at some point... How do you convert cache back to RFS? Is that some option available in CWM?
MEGAUPLOAD - The leading online storage and file delivery service
Also, if you've gone back to stock, the stock recovery will format the cache partition to rfs if you do a factory reset
also, after booting up for the first time after installing an Odin image, log into google through the add accounts interface in the contacts list. That has always avoided the Google Authentication issue for me
After booting up for the first time use talk sign into your google account it will sign in and sync and then go into the settings and uncheck automatic sign in.
Hey Guys,
New to rooting this phone. I recently uninstalled the phone.apk in error, now my phone has no service and several apps crash. I'm trying to use ODIN to reflash to stock, I've installed the USB drivers but I am getting connection errors.
When i plus my phone is on download mode, it says error installing usb drivers.
ANy ideas how I can fix this, or reflash back to stock to recover the missing app?
Thanks in advance guys.
Ive tried 2 different computers, cables and with and without drivers. Any ideas how I can just install the phone APK once again? Is it as simple as dragging the missing file onto the SD or phone memory?
Alright guys, I tried a THIRD computer and ODIN worked perfectly. I guess third time is the charm. Thanks everyone for your help!!
