Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Thanks for your work but it did not work I put the black screen and does not enter the recovery, I also have a D320N If you know any solution
me toooo.. flashed that zip and when it boot to recovery, it show only black screen.. :)
I'd like to thank vm03 for this great ROM. Works all fine and smooth. I was thinking to sell this phone but now I've changed my mind. :)
And, also if is a little offtopic, for me is necessary to thank also zlaja, a really good guy that helps me every time I need a help.
These are 2 of the people that makes this community great. Thanks guys
everything works fine including camera ( in d325f8 ) .. but cast and usb debugging not working .. pc runs into error and restarts ...
Third time I ask the same question?
I really appreciate all the hard work to make this low end phone amazing. But if I can't even get an explanation why my question is to stupid, not worth answering, I'm out of here. Seams like all other questions get a reaction except mine regarding "adoptable storage - still out of space on built in internal"???
Going back to cm12.1...
Anyways, thanks again...
Based on my experience, app installs are still on the internal storage, not on the adopted storage. The only files that will go to the adopted storage are the files on Android/data and Android/obb. Apk files are still located on data/app. I can say that adopted storage is only a " native Foldermount feature ". Only useful for games/apps that get their assets from the Android/data and Android/obb folders.
That's why you're getting a notification about internal storage almost full.
Edit: Or pretty much the same as the internal disabler zip we use on cm12.1
Hey, i screwed something up, forgot to wipe dalvik after flashing gapps, long story short - i now have crash error Unfortunately,Setup Wizard has stopped :(
Reboot to Recovery. Go to File Manager. Navigate to system/priv-app. Then delete the SetupWizard folder. Once booted, grant GPS all permissions.
Or you could drag down notif drawer, Go to Settings -> Apps then grant Setup Wizard the permission it needs.
I would say with this method GPS will crash from time to time. I had the same experience and it could be annoying. I recommend you to start with a clean flash and download the latest GApps.
You are wrong, some apps will installed on adopted storage, I have an app that uninstalled itself when switch back the sdcard to portable storage.
Bug again:
The latest TWRP still doesn't read the adoptable storage.
The MTP driver from my post earlier doesn't work on Windows 8
SOME APPS.
And most of those apps take little space. Maybe app devs have to do something with the app for better compalibity with adopted storage?
Even the cache is still stored on external.
Anyway, there will be a time when this bugs will be all gone, by that time N is coming. Lol.
After updating Nightly from yesterday. I now have problems with File Manager. File Manager doesn't see files and folders on internal and external sd anymore.:confused:
@vm03 Bugs on latest version:
1. File manager not working
2. When phone is on "Vibrate" and i restart it, it turn on sound again
3. Screen rotation randomly stop working
Hi, I usually dont post here, but i have some questions,
1. Does this rom will suport OTG? I remember this device had it on the original rom
2. Will come back knok code? I miss it sometimes
3 is it a rom bug that the music player crashes a lot?
4. In D320f8 are a strange lines on the camera, doest it had posibility of being fixed? Ill post some photos to show it
Someone else have wifi problems? my wifi disconnects when I turn off the screen, and when I turn on the screen is connected again immediately, first showing a exclamation mark for a moment (it's activated "always" in the Advanced Options -in case anyone is wondering-), I have tried all possible "solutions" and still happening, i don't know if it's an actual bug of this ROM... I have the variant MetroPCS (LG L70 MS323), Cheers :rolleyes:
Note: I think remembering that in "mobile data" is the same
Finally I can enable MTP on Windows 8.. Yay!!
And works perfect
Heres what I did
+ plug in usb cable to phone and PC
+ open device manager win 8
+ you should see your phone as "unknown device"
+ double click on it
+ on driver tab, click on update deiver
+ on pop up windows choose "Browse my computer for driver software"
+ on next screen choose "Let me pick from a list of device blablabla"
+ on next screen choose "Portable device"
+ and choose LGE Mtp (something like that) or if that doesnt exist you can choose just generic MTP (for me I choose the first one, cos that appears on my PC)
+ and voila, on File Explorer you should see Internal and SDcard now
+ confirmed by me can transfer large file without crash
### forgot to mention
After plugin your phone, you should pull down the notification bar, and choose MTP
1. No. L70's hardware can't support OTG.
2. No. Knock Code is a feature from LG's stock ROMs.
3. Yeah it crashes every time. Install another player. I'm using GP Music.
Hello to all, first of all i want to thank @vm03 for make this possible and and @BlueDev cause his answers were very usefull to me.
For LG L70 D325 DUAL:
About the phone is not recognizing SIM, RIL problem.
I had that problem, is because i had the wrong ABOOT file, if some of you are having this problem you just have to flash the correct ABOOT file from fastboot mode.
The PC is getting blue screen after conect the phone.
This is because of the driver as @BlueDev said before, i fix this problem because of him:
QUOTE: Also, I found solution for transfering data and using ADB on Windows... I had original LG drivers from site installed on my Win and after that I installed driver in resources below... After that I got BSOD again... Then I found (according to crashdump file) that driver usbccgp.sys on address lgandnetmodem64.sys+87c7 caused the crash... So I removed that driver C:\Windows\System32\Drivers\lgandnetmodem64.sys
This should fix the problem when you plug your device to your computer.
The rear camera is not working.
With the last update the rear camera works perfectly so what you have to do if you having this issue is install the 13.o version and update from the device when is ready and this should fix the camera, the flash of the camera is working too.
If someone is having this trouble and want more information can PM me.
I have the 13.0-20160112-NIGHTLY-w5 CyanogenMod, I think is up to date to the last version.
Now I want to make some open questions:
I been reading in this thread about somehing called "xpossed" and that is working, I want to know what "xpossed" is and what is the use for it, maybe I can try it.
About the rooting, I been reading all this thread and I saw some post saying to something about turn on on the developer options but I couldn't find this option, I read about give permission to a single app too but i couldn't find it either.
About the low volume, I haven't try this too much because I work and been busy but I want to know if this is fix in the last update, I was recording a song last night and when I played the record was too low, couldn't hear anything.
Thanks to all to take your time to read my post, if I can help let me know, I been doing this for days now and I think I have solutions for the LG L70 D325 dual.
Sorry about my english, I am latino lml
THANX for the advice given about blue screen error ..
I find an bug infecting apps on adopted storage. Icons on homescreen disappear after reboot/power on. Icons of apps on internal storage are OK. Any suggestions?
Hello guys. Im having some problem when setting up my external SD. Both setting up as portable and adopted storage is unsuccessful.
The sample toast message which appears is on the attached file.
I already tried formatting the external SD on both Windows and OSX but no luck.
By the way, it is formatted as adopted storage before it goes nuts.
Thanks!
