Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Several possibilities were presented.
Talk about what you did. And, what solved the problem.
If it was aboot.bin. You no longer need to flash this file. But keep it for future needs.
My problem was with my SIM cards that were not identified on the device (L70 D325f8-BR-PT) when I put the CM13 ... and make the flash file (Aboot.bin) I was able to fix ... and it worked.
Now I installed CM14 and it worked too (of course, with some errors still in CM14)
D
D
The CM14.1 or LineageOS must be applied through a clean installation.
You will see that the problems of apps that open suddenly close will no longer occur.
Clean installation:
TWRP BACKUP
Wipe (system - dalvik - cache - data - internal - android secure)
Tip: Go directly to LineageOS (Continuation and Evolution of CM14.1).
Clean installation:
TWRP BACKUP
ok.
I noticed a problem, connect to the computer in MTP mode or just charging, the computer starts a blue screen and reboots, but when switching to other usb modes the computer recognizes the device
This in both CM13 and CM14
ok.
Its not a CM issue.
Uninstall the windows lg drivers!
Search for the universal usb driver from google for android devices.
I leave windows install native drivers for usb devices.
Clean installation:
TWRP BACKUP
is lineage os for lg l70 stable? i mean without many errors
I'm usually using the Unofficial compilation from @ vladimirs77.
I put it in daily use.
It seems to me that he is making slight and cautious changes based on CM14.1.
Neither put bootanimation, yet.
It may be that there is something of a very complex and subtle level, which is not even perceptible as a problem itself.
The ROM is running smoothly.
My consideration is that there are no obvious problems.
I installed (lineage-14.1-04.01.2017-UNOFFICIAL-w5) with (open_gapps-arm-7.1-pico-20161230) on my LG-L70D325f8 and the errors I realized were:
The master user photo is not loaded in the status bar
The SIM CARDs toggle button does not work
(Something I personally did not like was the lack of the theme manager ... and maybe that makes me stay in CM13, but I'll do some research)
... for now I only realized these
I have been using CM 13 on my LG D325 for the past one year . However, after the latest nightly update (released on 25-12-16) , Google Play Services kept crashing. So I applied my previous working nightly (released on 22-11-16) . But now even that doesn't work. Now, I cannot get past my LOCK screen. I have a TWRP bacup on my pc but I am unable to go to recovery mode to apply it. Help me guys!!
Will this work on the MetroPCS LG Realm. They are pretty much the same phone except the LG L70 is for T-Mobile.
Well, rather impossible - not to mention Realm is actually a different model (i.e. LS620). Few people from xda tried custom roms for similar models (L70 too) but with no luck. All you can do is install some older TWRP from xda, but still no custom roms.
1 Get sure your phone is at least 60% charged or is charging battery
2turn off the phone
3use the steps to enter recovery mode manually
(It's been a long time since the last time I entered manually, and, to be honest I don't remember well the combination so this video can help u
4save the back up from your computer on an SD and insert it into the phone
5delete the Dalvikcaché and cache
6search the route from the sd file in the recovery and restore the backup you did in the BACK UP seccion, NOT in the install one
@Roberthf has given some tips, but you may also try entering your recovery without a SD card to see if it works. As I understand, you cannot enter recovery because it's stuck on a twrp splash screen?
Have you tried dirty flashing some other gapps package as well?
