RodrigoFS
Its not a CM issue.
Uninstall the windows lg drivers!
Search for the universal usb driver from google for android devices.
I leave windows install native drivers for usb devices.
It worked!
Thanks a lot for the help
Its not a CM issue.
is lineage os for lg l70 stable? i mean without many errorsThe CM14.1 or LineageOS must be applied through a clean installation.
You will see that the problems of apps that open suddenly close will no longer occur.
Clean installation:
TWRP BACKUP
Wipe (system - dalvik - cache - data - internal - android secure)
Tip: Go directly to LineageOS (Continuation and Evolution of CM14.1).
I installed (lineage-14.1-04.01.2017-UNOFFICIAL-w5) with (open_gapps-arm-7.1-pico-20161230) on my LG-L70D325f8 and the errors I realized were:I'm usually using the Unofficial compilation from @ vladimirs77.
I put it in daily use.
It seems to me that he is making slight and cautious changes based on CM14.1.
Neither put bootanimation, yet.
It may be that there is something of a very complex and subtle level, which is not even perceptible as a problem itself.
The ROM is running smoothly.
My consideration is that there are no obvious problems.
Will this work on the MetroPCS LG Realm. They are pretty much the same phone except the LG L70 is for T-Mobile.
I have been using CM 13 on my LG D325 for the past one year . However, after the latest nightly update (released on 25-12-16) , Google Play Services kept crashing. So I applied my previous working nightly (released on 22-11-16) . But now even that doesn't work. Now, I cannot get past my LOCK screen. I have a TWRP bacup on my pc but I am unable to go to recovery mode to apply it. Help me guys!!
Cyanogenmod is dead, you need to use Lineage os.
What model do you have? I have the w5(ms323) If you know exactly what model you have check here http://vasy.ru okay!
And if not maybe you can use Aosp Extended. It is my favorite rom for this device!
