Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
I chose mini. I wanted to flash it over the gapps I already had, but since I couldn't get it to install I just stuck with the ones already installed.
Pico version is recommended - you can still download various Google individual apps from the Play Store later on. Don't need to upgrade to the bigger package :)
...and after installing back CM13 my phone has been attached to the PC when this appeared as a name of the phone lOl
No, you need a stock or CM13 modded partition table, with 1100 MB for a system partition.
@Mystery_Flasher , you commented in the topic of the CM14. But since I am testing the CM13, I prefer to comment in the correct topic!
I am using partition with 960mb of space, in the CM13.
The use with busybox, xposed, gapps micro, is in 910mb.
Supersu now is installed together to the user apps.
Also I install the Google Play Services in the user apps.
Google Play Store: I maintain in the system apps. And, And, I merge the versions updated with Lucky Patcher.
Completely tested in these last two days.
Now, what the problem of the camera of the D325f8 (three characters unjustly positioned in the "build.prop" ;)) were resolved by it. I left the Stock, once and for all.
I will be more present in the forum, again!
@Mystery_Flasher , você comentou no tópico da CM14. Mas já que estou testando a CM13, preferi comentar no tópico correto!
Eu estou usando partição com 960mb de espaço, na CM13.
O uso com busybox, xposed, gapps micro, está em 910mb.
Supersu agora é instalado juntamente às aplicações do usuário.
Também instalo a Google Play Services nas aplicações do usuário.
Google Play Store: mantenho nos apps do sistema. E, mesclo as versões atualizadas com Lucky Patcher.
Tudo testado nestes últimos dois dias.
Agora, que o problema da câmera do D325f8 (três caracteres indevidamente posicionados na "build.prop";)) foi resolvido. Abandonei a Stock, de vez.
Estarei mais presente no fórum, novamente!
How do you say you install Google play services and play store?? I'm interested
I don't quite understand what you are trying to say :) It sounds interesting, though.
If I'm right, you've successfully flashed CM13 alone to the 960MB system partition and then an individual Gapps applications to the data partition?
Don't get me wrong, but your solution is no good to me, since it involves hacking things with LP (which shouldn't be promoted here :) )
About the partition size:
I already had a prior installation, recommended partition size. I made the backup by TWRP.
Repart and restored my Backup. It worked fine. But when performing a clean install the rom is stack in: "Patching system image uncondicionallly..."
So, I think I need to repartition again. :p:D
About the "Google Play Services":
Takes up a lot of space on the system partition. Previously I'd save the apk, uninstall the "Google Play Services" from system; and, just reinstall.
About the "Lucky Patcher" and "Google Play Store":
It helps Me on "Google Play Store" updates integration along with the system factory versions. Since when is updated are two copies. One in "/system/priv-app/" and another in "/data/app/".
Previously, in the KitKat I was saving the updated "Google Play Store" apk from "/data/app/", uninstall update and the factory version, reboot, and... (without new install) I just copy the updated version to "/system/priv-app/".
I only called attention to the function of "integration". No apologies to malicious hacking modes! OK?o_O
If you know any other app that integrates updated versions with the system factory versions. Make the suggestion for me! :)
anyone knows how to decrease the sound volume recorded with video recorder?
The sound recorded is too loud..
@vm03 I found small bug. In headphone buttons vol- doesn`t work. I have Xiaomi Piston V3 headphones. Button volume down work in stock and cm12.1 by @vladimirs77
Code:
648.305346] [LGE MBHC] High Impedance Headset(Apple) is detected. Enable MICBIAS and report 4pin headset.
[  648.311614] msm8x10-wcd-i2c-core msm8x10_wcd_codec: msm8x10_wcd_codec_enable_micbias 1
[  648.315411] msm8x10-wcd-i2c-core msm8x10_wcd_codec: msm8x10_wcd_codec_enable_micbias 2
[  648.336460] [LGE MBHC] Headset is Inserted. jack_type:0x3
[  653.121876] [LGE MBHC] wcd9xxx_dce_handler: enter
[  653.195764] [LGE MBHC] wcd9xxx_dce_handler() DCE:582, button:7
[  653.197198] [LGE MBHC] Unsupported button event. Ignore button event.
@vm03 Could you fix it?
Hello everybody,
I have an internet problem at outside after i switch this ROM. I have mostly ! symbol inside signal strenght and 2G/3G symbol... And i can not use internet outside... But WIFI is okay... At home there is no problem...
At outside... Very seldom i have internet... But %90 of time i have no internet...
Any Idea? Any solution?
