Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Missed out on the existence of both an official and an unofficial thread... Tried to read it all and after the latest update this rom is just amazing :)
Got used to installing zips from a separate sdcard and all seams to work well. Still the annoying mobile data drop, but after googling around it seams to be a general problem on T-Mobile right now. Not sure it's marshmallow or some changes in the network? Xposed works flawlessly, charging works well and my battery lasts around 12 hours with normal use.
I found that swapping between theme's makes the icons come back in the notification drawer.
Just a question:
When the system warns me the internal is full, should I ignore it, is it just a bug? Will it just continue to fill up my 64gb extended internal (sdcard)?
Thanks again vm03 for all your hard work...
Edit:
Oh yes, thanks for the twrp update! Will flash it tonight ;)
Anyone knows how to take a screenshot?
About root:
Anyone knows how to give permision on this rom to each app? That is still a enigma for me :P
Last TWPR flashed from fastboot and up to date CM13 now running, now pls help me with the root information :D :D :D
Go into the menu in the picture then tap build number 5 times + then go into development settings and change root
uninstall the app with link2sd, reboot and install again, then convert the app to the system with the same app, reboot again and do the same steps to activate now on tap
Nothing happens. But now noticing, what actually happens is that when I press menu button it makes a little vibration (from the actual menu button function apparently) and then vibrates again, not sure If is related to Now on Tap, but by the moment it just don't work for me.
Try using google launcher, and then reinstall the google app. It is all I know
Do you know if this latest update has solved the problem of audio recording with the volume down on the D325F8 CM13 model , has already been solved ?
Thank You :)
I flashed the recovery TWPR version 2.8.7.0 on my MS323, but when I try to enter recovery mode the phone shows me a blue screen with a logo "teamwin" and is frozen, it does nothing. Do not show me recovery options. The phone starts well but the system does not let the recovery to perform advanced tasks.
I have a problem with usb cable first time when i used , my comp recognize my phone but didnt gave me
to enter in the phone , after i re enter ptp in usb mode then recognize it and i transport files,
now i try the same thing but comp windows7 dumps any help?
other answer super su binary need to be updated but when i go trough TWRP to install update
and freeze
when my sd card is in my phone and i try to reboot to this new recovery the screen shows lg logo and then goes black... There is a sound when i connect it to pc but can't access it...
Edit: adb shows it's in recovery...
d325f8 : TWRP does not work when the sd card is as internal storage, only works when it's as portable storage
Ok now testing the all-new TWRP version, It just have 1 little problem. When I want to flash the GApps Nano it says I don't have enough space (I didn't had this problem with the old version, so I though it might be a bug). But I could flash the GApps with Sideload.
Edit: Now on Tap is working now (D320n)
Hi. I want to install this rom on my LG L70 D320g8.
Someone already installed in the D320g8?
What bugs have?
Recovery which I install?
What gapps install?
I have to know something else besides unlocking the bootloader, install the recovery and install the ROM?
I am a newbie at this.
Sorry for my bad english, i use a translator.
