in dmesg:@vm03
NFC isn`t working again
[ 45.551685] pn547_dev_write : i2c_master_send returned -110
I don't have idea how to fix it...
in dmesg:@vm03
Thank you, but could you explain that to me ? Now I have installed operating system ubuntuUse linux.
I don't know how fix the problem, so use Linux every time i use developer mode.Thank you, but could you explain that to me ? Now I have installed operating system ubuntu
reformat sd16/01/2016 sd not working @vm03
this SD and internal storage is a shit, blessed linksd2 not there problems with that all the partition and ready
I unlocked my D325f8 using laf_script.bat and then rooted the phone, both root and unlock worked perfectly.
The problem is that I tried CWM and TWRP but whenever I reboot into recovery I enter the "pink error" screen.
The phone still boots normally when not in recovery mode and also boots perfectly in download mode but recovery mode isn't working.
I want to go ahead and install a custom recovery to flash this rom, can someone please advise what should I do now to fix the pink screen error and install successfully TWRP or CWM?
Thanks
The screen:
I have the same phone model you ... so I'll leave a little tutorial to get you unlock the bootloader it.
Just remember that this is a temporary release .
[ Important ] When you return to the stock rom the d325f8 , the same unlocking becomes inactive , returning to normal bootloader lock , and around it , just repeat the unlocking process.
Link Process " Unlocked Bootloader L70 D325F8 ".
- Well the custom recovery process is very simple to do , because the more difficult it was to unlock the bootloader , you already did.
To install a custom recovery , I recommend you use the flashfy , a great application that runs the installation process very well.
And if you are installing the cm13 in D325F8 model , it has some bugs that bother you, depending on how you use your phone on a daily basis . Follows two main :
- Strange stripes when taking pictures and also in photo viewing [ NO FIX ];
- Problem with the audio recorder, is the main application of the system or any other type of application, with eg Whatsapp and Third Voice Recorder. The volume even after the recording is ridiculously minimum [ NO FIX ];
Regarding the audio capture on calls and recording videos , it is flowing naturally without any problems.
I'm thinking about upgrading this area whenever there are bug fixes in D325F8 model
Priority is the major
I found out that it only happens when I am using adapted storage and I try to reboot. When I take out the SD Card it works. Also note that sometimes I get Google Play error 963, maybe it has something in common... Can someone help me? Using 18/01 buildThat ia weird, i updated to latest by downloading and wiping then i reflashed because i like to start clean. I haven't had any issues so far idk.
Thanks all.
I installed [ cm-13.0-20151217-UNOFFICIAL-w5 + aboot.bin + TWRP 2.8.7 ] on my LG L70 D325f Dual SIM.
My SIMCARDS work well and every thing is ok.
But my HOME key does'nt work correctly and sometimes my gallery doesn show pictures and show gray frame!
It works like setting botton!
I chenged the Bottons in Setting menu, but it doesnt work yet!
Do you know any way for solve it?
Quick Settings only has brightness control.Major issue with LG L70 D320n build cm-13.0-20160119-NIGHTLY-w5. No icons, Status bar empty.
You need to send d320f8 device to vm03.Please fix the problem of camera d320f8, is the only issue which does not use the rom diariamenete, the camera shown is only the front, it would greatly appreciate it, in all more than the rom this perfect good for everyday use. Thank you
SORRY; Daniel rdgzAndroid, vm03 need to have the lg l70 d320f8 physically to fix camera and other bugs, if not d320f8 in hands of vm03 NO FIXES, unfortunately for d320f8 owners, The only way is that you (owners d320f8) send a lg l70 d320f8 to VM03, I said.Please fix the problem of camera d320f8, is the only issue which does not use the rom diariamenete, the camera shown is only the front, it would greatly appreciate it, in all more than the rom this perfect good for everyday use. Thank you
page 10 post 229-230 and 235 from cmging.Now on Tap? Nobody? D320n?
