Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
@vm03 Strange issues with new Nightly's from date 19 and 20 with d320n. Quick Settings only has brightness control.
Did fresh install. No special settings or apps installed after flash on Nightly from date 20. Quick settings are gone after reboot only has brightness control.
Strange! If connected d320n to computer with USB Cable all Quick settings are back. After reboot gone. And so on:confused:
Think it has something to do with Android USB debugging
Debugging on: After reboot Quick settings are back when d320n with USB Cable connected to Computer, when disconnect USB Cable from computer all Quick settings persists.
Debugging off: After reboot Quick settings are gone. And even with USB Cable connected to Computer Quick settings not came back." Only has brightness control"
Hope this information helps.
Hold gear icon (between battery icon and user) until System UI tuner appears. Then just mess with the toogles (I added 1 toogle with mine), tap done and you're done.
that heavy ****ing camera with the f8, none was able to donate anything or send a terminal to @vm03 and all the threads of all the same question roms
the first launch of cm13 for l70 sent some locagts him soon after the camera began to work in d325f8 , but she still has a white stripe in the middle, yet consider a major advance what he did for this device.
Hello guys, I have the LG L70 D325 DUAL and i have perfectly installed CM 13.0-20160112 nightly-w5 wich is fine in every way, but now there is an update available cm-13.020160120-NIGHTLY, the thing is when I download the update and restart my phone to TWPR I can't find the update to flash it, I am guessing the problem is that I have my SDcard as an intern memory and the TWPR can't read that format, thank you for your time and for your answers.
Suggestions? I really want to be up to date and share my experience.
No idea if I should have made another thread or post this here.
Anyways. There's NO way that the F8 will ever be at a fully functional state until a F8 is sent to one of our devs. It's simply impossible to work out bugs for a device we do not have. without breaking functionality of another variant.
For those saying 'blah blah try living without a camera' 323 USERS DID THE EXACT THING. We lived without a back camera for months. Thread after thread of someone promising to send a camera. Most never did until someone did. The second @vm03 got his hands on his device, it was fixed in less than 24 hours (my minds rusty here so I'm not sure about exact estimates). Then after a few weeks for heavily working on the 323. It turned out as stable and as solid as the 320n roms out there.
So unless you guys send a device. You're out of luck. I lived through camera hell too, I guess you can too until someone sends a device.
//end rant//
I'm not sure that much changed, however when i booted it took less time, and love the new look @vm03.
Plus the adopted storage support
Missed out on the existence of both an official and an unofficial thread... Tried to read it all and after the latest update this rom is just amazing :)
Got used to installing zips from a separate sdcard and all seams to work well. Still the annoying mobile data drop, but after googling around it seams to be a general problem on T-Mobile right now. Not sure it's marshmallow or some changes in the network? Xposed works flawlessly, charging works well and my battery lasts around 12 hours with normal use.
I found that swapping between theme's makes the icons come back in the notification drawer.
Just a question:
When the system warns me the internal is full, should I ignore it, is it just a bug? Will it just continue to fill up my 64gb extended internal (sdcard)?
Thanks again vm03 for all your hard work...
Edit:
Oh yes, thanks for the twrp update! Will flash it tonight ;)
Anyone knows how to take a screenshot?
About root:
Anyone knows how to give permision on this rom to each app? That is still a enigma for me :P
Last TWPR flashed from fastboot and up to date CM13 now running, now pls help me with the root information :D :D :D
Go into the menu in the picture then tap build number 5 times + then go into development settings and change root
