Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
@vm03 the rear chamber of the device d320f8 even does not work, only works the front camera is dipositive of Mexico, could you please fix the rom what is a rom excellent fit and excellent work she has done.
or you can help me to fix it. :(
After reboot nfc disappeared.
how do I update cm ? as it downloads the update after restarts TWRP , but soon and for myself I find the upgrade to install manually
1.The best way is to backup all your data (photos,and files from internal mannualy)
2.next i would recomend to do full system backup (data from apps,etc system files)
3.it's not the same thing (1 and 2-nd step)
4.then wipe all (also copy the rom and gapps on sd card,)
5.proceed the procedure as usual,etc. flash rom and gapps then st all up again :D
friendly advice,use sd card that have more then 8gb or 8gb.
Read carfuly
Sory for bad english,typing from on-screen keyboard
^ Put simply:
1. Back up everything that is important to you(store it somewhere outside your smartphone)
2. In TWRP recovery make a backup of your current system
3. Download the latest cm13 build (link in second post) and pico gapps from opengapps.org
4. Put cm13 and gapps on your external SD card
5. Boot into TWRP recovery
6. Make a full wipe(Wipe > Advanced Wipe)(don't wipe your external SD card ofcourse)
7. Flash order: first cm13, second gapps
8. Wipe Dalvik cache just in case and reboot to system
9. Be patient.
^ Put simply:
2. Download the latest cm13 build (link in second post) and pico gapps from opengapps.com
3. Put cm13 and gapps on your external SD card
4. Boot into TWRP recovery
5. Make a full wipe(Wipe > Advanced Wipe)(don't wipe your external SD card ofcourse)
6. Flash order: first cm13, second gapps
7. Wipe Dalvik cache just in case and reboot to system
8. Be patient.
I usually just download latest cm 13 and flash without wiping. I never had any problems and I don't have to set up anything, everything is where I left it.
I didn't update gapps after I installed all my apps though. I don't know if that is a problem.
I updated gapps after I logged in my Google account. And it worked fine.
This is how I do it, might not be the safest way though. :)
^ Yes, it's not the safest, but it is doable. I personally prefer making a full wipe so I won't have to encounter problems I could've avoided easily.
the problem is that my sd ta in internal format and low when the newest update cm can not find it in TWRP
I have the same issue, just download the cm13 on the PC and copy it to internal storage via usb. If you don't have enough space you can use a second sd. I remember that I was able to see the sd in TWRP when I partitioned the sd from recovery.
Hope it helps.
it changes nothing. cs_emergency, diag or emergency its the same.
after a few hours of 10% the software stops running and aborts the data transfer.
i think the problem is the cellphone (not the drivers or the lg mobile support tool).
Did you fix the pink screen?
