im trying to install cm13 on a lg
l70 d325 (the duel sim model).
installed twrp successfully.
installed cm13, and gapps (nano version).
then at reboot pink screen. at this point i was only able to get pink screen or fastboot mode. via fastboot installed the laf.img in order to go into download mode. (fastboot flash laf laf.img)
at download mode i can connect the device to a pc and using LG Flash Tool 2014 i get this:
i tryied several kdz versions ( D320AR10a_03, D32510d_00, D32510e_00, D32510f_00 and D32510g_00, im not able to find versions a b and c).
it doesnt matters how many times i try to install any kdz i always get stuck at 10% of the installation.
i boot the device into firmware update:
select emergency at the lg flash tool and 3gqct. then the programs starts, it checks the windows os, extracts the sofware, at this point cellphone shows on screen
"com 7"
u user s0.0 as0.0 b91 uhs
u ud lg-d325 06.0.1 hrev_10
d32010n (i think i installed via fastboot the aboot.img of a d320, not sure at this point)
d32510f
rooted
sry if my english is not too good![]()
Same problem here. I tried on 32MB and 16MB cards...same errorHi all,I have a problem with the Adaptive storage, trying to convert my SDcard on internal storage CM13 detects it as if it were too slow. and to transfer the data from all the applications restarts the settings or configuration. And Yes,I have tried to activate it from the terminal but still does not work. :cc
The model of my phone is D320F8
and the SDcard is Adata premier class 10 with R/W speed of 50 mb/s![]()
I know one way, but only I checked in d320f8, i dont know if this work in another model, you can try, but before editing creates a backup of the default file, and notify if it works for anyone else who wants to do the same.how d
o I increase default loudspeaker volume...?
its too low
You overwrite the default file, located in "/system/etc", and apply permissions "rw - r -- r--", or "0644", you can do it with root explorer/browser.
File: http://bc.vc/IpXJZD
source:
I think not, this is only to increase the volume of Earphones or Speakers.This is to increase the volume of audio recording ?
As I said up there , I'm having trouble on system and app Whatsapp , recording sound what I do , I go very low , hindering a little understanding.
From what I have tested in calls or video recording , the mic is excellent.
It should work. I had one and it worked for meAnyone here uses a 64 Gb SD card on L70? Does it work? I'm planning to buy a new class 10 64Gb SD card for adoptable storage and more space.
The current one I'm using is a class 4 32 Gb Toshiba SD Card.
1 both give my win7 bsod when connected to pc via MTP
What does mainline means? On the next release?adopted storage fixed in mainline. separate fix no more needed.
Yes there is new update cm-13.0-20160111-NIGHTLY-w5.zip. I have installed it, but addopted storage still doesn't work for me.
Can you post dmesg at early after boot?When switched NFC on, is immediately switched off. 20160112
