Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Apparently formatting the SD as internal storage does not work on 06 and 07 versions. Did not try it on 08.
I managed to do a workaround by flashing the last version of the unofficial cm 13 and then updating it to 07. Did not update to 08 yet.
I have one more issue with the now on tap which crashes my Google app when I activate it. I have noticed that now on tap worked if I used the nano version of gapps
I use "pico" gapps and works now on tap, but first install Google Now launcher and then the application google, After enabling now on tap no longer gave me error, then uninstall google now launcher, and i continue using nova launcher and so far has not failed, just hold down the menu button
I use google now launcher, still not working. I will try uninstalling Google app and reinstalling it.
Anyone also experiencing problem with Formatting SD as internal on latest build (20160108)? After the format process it says that the SD card was corrupted.
I had the same problem on 06 and 07. I managed to do a workaround by flashing the last version of the unofficial cm13 format the sd and then updated to the 08 version.
how to use the zip? Install via TWRP?
Try to install via TWRP. if you get error, use adb:
su
mount -o rw,remount /system
cp /sdcard/fsck.f2fs /system/bin/fsck.f2fs
cp /sdcard/mkfs.f2fs /system/bin/mkfs.f2fs
cp /sdcard/libf2fs.so /system/lib/libf2fs.so
mount -o ro,remount /system
Using LGMS323, tried flashes 1/8 first and 1/4 to see if it was more stable
1 both give my win7 bsod when connected to pc via MTP
2 on 1/8 I get an err_file_exists message when trying to websurf
3 error when using TWRP to install adoptable storage fix
which one of these last 5 builds is the most stable or reliable?
How to change status bar to transparent in cm-13.0-20160108-NIGHTLY-w5 build? its annoying :\ Also where do i submit bugs to this rom? Ear speaker (one you hold on ear when speaking on the phone) is so damn quiet, even when i bump it on max :\ please fix. Other one ( for music) is ok.
After upgrading my phote to cm13 from cm12.1 I can't update su binaries(super su). How to do it?
Liked the new camera app, now everything works fine except for video audio.
Edit: Can't make work Now on Tap
So this is how I managed to get now on tap and adopted storage to work.
First flash the latest version of the unofficial cm13 then flash open gapps pico after that boot up and format sd as internal storage and log in with the gmail account on Google play app. After that update to the latest official cm13 and flash opengapps nano.
I tried flashing open gapps nano from the start but I got an error telling me I don't have enough space.
This worked for me, hope it helps.
Hi all,I have a problem with the Adaptive storage, trying to convert my SDcard on internal storage CM13 detects it as if it were too slow. and to transfer the data from all the applications restarts the settings or configuration. And Yes,I have tried to activate it from the terminal but still does not work. :cc
The model of my phone is D320F8
and the SDcard is Adata premier class 10 with R/W speed of 50 mb/s
im trying to install cm13 on a lg
l70 d325 (the duel sim model).
installed twrp successfully.
installed cm13, and gapps (nano version).
then at reboot pink screen. at this point i was only able to get pink screen or fastboot mode. via fastboot installed the laf.img in order to go into download mode. (fastboot flash laf laf.img)
at download mode i can connect the device to a pc and using LG Flash Tool 2014 i get this:
i tryied several kdz versions ( D320AR10a_03, D32510d_00, D32510e_00, D32510f_00 and D32510g_00, im not able to find versions a b and c).
it doesnt matters how many times i try to install any kdz i always get stuck at 10% of the installation.
i boot the device into firmware update:
select emergency at the lg flash tool and 3gqct. then the programs starts, it checks the windows os, extracts the sofware, at this point cellphone shows on screen
"com 7"
u user s0.0 as0.0 b91 uhs
u ud lg-d325 06.0.1 hrev_10
d32010n (i think i installed via fastboot the aboot.img of a d320, not sure at this point)
d32510f
rooted
sry if my english is not too good :p
"com 7"
d32510f
rooted
Try changing the"Phonemode" from "EMERGENCY" to "DIAG" :v
My English is not very good too :c
Hello everybody, I have a little problem , and would like your help .
I have a problem in the audio recording volume , it is very low , mainly recording system app itself and whatsapp .
Already called the mic volume is perfectly normal.
Please help me
it changes nothing. cs_emergency, diag or emergency its the same.
after a few hours of 10% the software stops running and aborts the data transfer.
i think the problem is the cellphone (not the drivers or the lg mobile support tool).
