Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Well, I don't know what the point of partitioning the SD as internal is if most apps won't install on it. Disappointing. Am I missing something?
Heh, you need to learn how the adaptive storage works :confused:
Formatting your SD to internal memory ("adaptive storage") was introduced to let users decide if they want to use SD cards as a portable storage (classic way), or format it, encrypt and use as a part of the system. When using the adaptive storage, your apps store their data and *obb files on this newly formatted SD-card. This is a great benefit of the adaptive storage. Still, some part of an app cannot be stored on the adaptive storage, APKs for example. What is more, after formatting, your SD card can no longer be used with your PC or other card reader, unless you format it back to FAT again.
I understand that... But that's not what's going on. Its not "part of the app" that's taking the space. It's the whole app and its cache. Like I said I don't see the point in it if most apps end up 100% in the internal storage. I only got an extra 400mb worth of apps out of this and since the internal memory is full it won't let me install anything else unless I make some room in there and cross my fingers in hopes the new app will install to SD. If it worked like you say, then I would guess the 1.48GB of internal memory would be plenty to host all apks. I mean I don't even have that many apps at the moment.
All that being said, I guess it still beats the alternative: even less space.
You can always repartition your internal memory like many of us did and enjoy 2,6GB of internal space + adaptive storage.
I hardly even remember having 1,48 GB of internal space with my L70. And I have no complains whatsoever.
I would say that knowledge of @vladimirs77's Partition Table Tool or Kamil Mazik's partition script should be obligatory before entering this forum :D
Repartitioning before entering this thread should also be one of the forum rules, so we can all skip that part of complaining about low internal space :D
Dear L70 brothers, there are tons of infos over the internet regarding how much internal space this phone has, and still we buy and feel bad about it :p
I have tried that before without success. Thanks for bringing it up; on second look I see what my problem was. I own a ms323 and OP is not up to date for our device. In case other ms323 users have tried and fail, here's the latest script. 2,6GB :D!
Yeah, I noticed that too.
The battery percentage text is a little too big than usually it is. So, there's a bit conjunction with the circle. That's what makes it unclear.
Also sometimes it'll freeze. I only notice while charging so no biggie.
Hello friend.
Why i'm can't flash official cm13 on my device l70 d325?always stuck on "Patching system image unconditionally" w/ flash official cm13?
But,i can flash unofficial nemelles rom 3.0 no problem.
Any help me please.thanks.
Hello friend.
Let me guess, your internal memory has been repartitioned to suit cm12.1? If I am right, repartition again but for Cm13 this time. It should do the trick
I hVave used vladimirs tool to repartition internal memory, but I have bricked my phone. Then i tried many things to relive it, and finally I am stuck at file system type. What are file systems used in L70? FAT or EXT4? I mess all partitions system, data, cache....
thanks
thanks
Using kdz cse flash should bring stock partition table back. Didn't it work for you?
I can't use Lg flash Tool, because I get common error "the phone is disconnected from pc".
Common error? ;) I would not agree, since I bricked my phone many times and a couple of times when partitioning in a wrong way, and have never seen what you say. I always had a working key combo to enter download mode and use Flash Tool.
Does a key combo work for you? Can you enter download mode?
Yes I could enter download mode.
And I also remember that one time I have done it and I only remember that I lost many time on it, but can't remember how I have done it.
Why, I am talking about common error - just google it and You will see, but all suggestions are, use good usb cables, reinstall drivers, reinstall pc OS ?!?!... and blablabla i don't get it really
Well, I see you lost your patience on it so there's not much to be done here ;)
Those suggestions are OK, I mean this is the way people deal with disconnection problems. I would recommend trying same things, as those tricks actually works in most cases. And I don't need Google to know that.
Good luck anyways.
If you don't want to reinstall windows, then use another PC, one ore two of them. This kind of problem happened to me too. Sometimes it works in one PC, sometimes it works in other PC.
Whats your battery life like I'm pretty impressed.
hi, i come from 12.1 and wanted to wype everything first to install latest 13 but when i entered TWRP (2.8.0.7) i got this error about error mounting system when tried to install the zip, i tried to reboot but got stuck in LG logo, i updated my TWRP to last (3.0.2-0-20160407) but same error and still stucked in LG logo, what can i do?
Hi, so did you manage to finally wipe before flashing the rom? If you are sure that your ZIP is not corrupted or something, maybe you should try with another nightly.
If your are stuck in LG logo, you should still be able to enter download mode with a key combo and USB cable plugged in.
Hi i want to install cm13 in my lg l70 320n but i have not really understood the issue of low internal storage. Let me explain better: with the stock lg rom i use link2sd but now with cm13 it doesn't work anymore. I don't want to use the adaptive storage of marshmallow because i need to have my sd card readable by my pc so i don't want marshmallow to format my sd card as internal storage. I just want something like link2sd in order to move some data of apps on a partition of sd card.
Can please anyone make a guide how to increase internal storage or something like that for cm13?
I have read about this guide but it is not so clear what it does and how to install it (if you use it can please tell me what i have to download and how i have to partition my sd card in order to use it). I also have found this on the web (i have tryed it and works but then i still have the issue of low storage when installing new apps), does anyone know it?
One last thing does anyone have problems with windows 10 and adb drivers? because when i activate debug usb and connect my phone (with cm13) to the pc (with windows 10), the pc crashes with the blue screen error. And also my windows 10 pc does not reads mtp on cm13. The same pc has no problems with the stock lg rom.
well after all i couldn't make it work i even downloaded previous nightly and got the same error,, but i did install cm 12.1 and not stuck anymore, i could be something related with the partition? i repartitioned and disable my internal in my cm 12.1 before i dont know if that helps
I can tell for sure that the problem might be your partitions' size. I experienced it myself. CM13 requires a bigger system partition than cm 12.1, so you need to use Partition Table tool again, but choose CM13 this time. It worked for me instantly. I used Vladimir's tool, not the cmd script version, btw.
Hi, the first guide you've linked is Vladimir's tool which operates on the phone's internal memory. It changes stock partitions' sizes so we can enjoy more space for data. It has nothing to do with sd cards. It's a remedy for a low stock internal memory, since you get 2,6 GB for data instead of 1,4 GB. It works from within a compatible recovery.
Using tools like this is always risky, but the benefits are incomparable. You should try it yourself and read instructions carefully, there's no better way.
The second link is for a trick I never tried and it doesn't come from this forum, so lets skip it.
All your concerns has already been answered in this thread. I know it's a lot of pages to read, but you need to do it. BSOD in win8/win10 has been answered like thousands of times, btw
