Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
i am experiencing fully brightness before locked screen.
does it happen to you guys?
or am i missing something to fix it?
im using latest image from this thread : http://androidforums.com/threads/di...oid-lollipop-and-partition-table-tool.921136/
the image : cm-13.0-20160521-UNOFFICIAL-w5.zip
I also experienced something like that, I use the last night of the official website of cyanogenmod, and that problem is not solved
Edit:
also it has another small mistake, that when the battery is downloaded and want to connect the device off, no symbol Released the loading and off the screen matiene
Thank you very much for the work you've been done @vm03 is impressive polished leave rom, I have several months testing it and improved in many respects, thanks for taking the time to be developing and improving rom is incredible;):D:D:D
Okay first this is already in another form, second it was just show or is to be shown this month. We have a quite a few months before cm14 is out. If we are going to get it, I wouldn't ask for any eta's
I would ask those crying for Android N to tell why they need it so badly :D
I doubt they would tell any important differences ;)
That's the story that is repeated over and over every time next increment in Android versions is released. And I'm in custom ROM world since Gingerbread 2.3.7. People usually want the latest release only because it is THE latest, without understanding the real benefits of upgrading, or even realizing if it IS worth upgrading. I have even seen people upgrading to a newer increment full of bugs, instead of staying at the current stable version (I'm talking about upgrade from ICS to JB on Xperia U, it was a nightmare until KK came). Luckily, vm03 did an excellent job, and MM on L70 is a real jackpot :) especially battery-wise, I think there's some witchcraft here, since I recharge my phone every two days now, as on stock :D
Yep, I was preparing everything right now jaja thanks m8
Edit: I don't know what I did, but apparently now I can't install Nano GApps (I installed Pico). I need to do repartition to 2.6 Gb? :/ (I've never repartitioned internal memory)
If you are using a stock partition table, there's no need to repartition, since stock system partition size is enough to store cm13 + GApps. Are you sure you do everything correctly ? What's you recovery version ?
Wifi disconnects and reconnects constantly for some reason but when I try a different ROM the wifi stays connected the whole time
No wifi issues were reported for a long time. Did you clean install the latest nightly ? Also, make sure your recovery is up to date. I'm on the latest nightly flashed through twrp 3.02 and have no problems.
Somebody else missing Play Store and contacts? :(
When I see posts like these, I think : God, there are some miracles happening to our phones. You wake up in the morning and suddenly no Google Play, no contacts, and your L70 no longer has 8 cores and 4gb of ram.. :D
Those miracles never happen to me, and I've been flashing custom roms for ages :D
Uuu.. this is deep
