Root Official CyanogenMod 13.0 for LG L70 D320 D320n D325 MS323
Somebody else missing Play Store and contacts? :(
When I see posts like these, I think : God, there are some miracles happening to our phones. You wake up in the morning and suddenly no Google Play, no contacts, and your L70 no longer has 8 cores and 4gb of ram.. :D
Those miracles never happen to me, and I've been flashing custom roms for ages :D
Uuu.. this is deep
No wifi issues were reported for a long time. Did you clean install the latest nightly ? Also, make sure your recovery is up to date. I'm on the latest nightly flashed through twrp 3.02 and have no problems.
I'm on the stable version idk if that's good enough but I have the up to date twrp but I didnt clean my phone or anything to flash it I just jumped on it from a different ROM
Headphone jack not working for me on 0524. Can anyone confirm before I do a clean installation or downgrade.
I have no idea what is going on with you phone, but I also think you did something that caused such situation. I never experienced such problems, with or without partitioning. Since I'm beginning to run out of ideas, I think the best thing to do would be flashing stock rom with kdz using CSE flash, and then you can again have fun with trying customs roms. I know it's time consuming but since you messed something up, there's no other easy way, I suppose :p
Well I haven't done nothing actually, I don't download apps, the only thing I do is download GApps and update the phone all days. I've been looking around, no idea, but doesn't matter anymore, I can live with Pico GApps by the moment.
**sorry for the delay**
Do I understand correctly, that you update your GApps every time you flash a new Cm13 nightly? If that's so, you don't need to bother with GApps once you already have them.
BTW, I also use a pico version and it's the best for me.
Hi! Thanks from Brazil, the CM13 feels awesome in D325-f8!
But I got two problems:
- There is a "shadow" in the back camera (frontal camera is fine);
- Device doesn't show up in Windows with USB cable;
Flashed yesterday's nightly version 20160528.
Hi, I will not even comment on f8 camera issues, since it's all over this forum :confused::p You should have seen those comments and repeated questions - no further comments necessary.
As for the USB problem, you may try changing your USB cable or installing Adb drivers from Google. You may find them easily.
Has anyone managed to install xposed? I swear it just doesn't work for me, the app says that the xposed framework isnt installed when I have flashed it like 3 times :confused:.
If you got it working what zip did you use?
I have closed running on my ms323, as of now I'm using xposed v84 sdk23 arm.zip haven't had a problem flashing it or anything, just when I soft reboot it says xposed is installed but into active, but a hard reboot fixes the issue. Hope that helps somehow :D
Alright so I updated TWRP to flash the xposed zip again but TWRP just staid in the initial screen and never loaded. Anyone with the same problem? Could it be caused by adoptable storage?
I use zip from here: http://forum.xda-developers.com/showthread.php?t=3034811
here's SS:
Someone know how install supersu and what .zip i need? I need busybox?
@Ang3l007 , using a search box next time would do you no harm :cool:
I just wrote about it yesterday :
For those who need a legal, free and up-to-date SuperSu from Chainfire:
http://forum.xda-developers.com/showthread.php?t=1538053
There are TWRP flashable ZIPs that I use for a very long time. If you want some extra features, buy a pro version and help the devs with their awesome job.
And no, Busybox is a different thing, so it's not required when flashing SuperSu.
@Maslovicz , it's working flawlessly on cm13 :).
Btw, I haven't seen you posting for a long time ;)
To me also the same thing happened. So i installed pico gapps but now on tap it does not work. You know if it is for the gapps? Before u hace installed nano gapps
