pixelpadre
Its not the usb connection that is the problem. The problem is there is no files visible when the usb cable is connected, even though I in fact have a gallery of photos that I can email.
I can read droid files, but there is no directory for pics. I suppose if I removed the card and plugged directly to my pc it would work.
Well, I did what you most recently said, then connected via usb. This time though all folders showed up when I was connected via usb. Last nite i did the same thing with no luck. Maybe I just needed to go to the file manager the first time to shake things up.
Thanks a million.,![]()
Is it for cricket? Or just metropcs? If the 2.2 is for cricket let me know please.
Running 2.2, cwm 3.0, rooted and tooted....went into rom manager and attempted to create a partition on the sd for apps, phone restarted and huawei white logo came up, and now it wont go away. Took battery out for a minute and still stuck. Tried to do recovery (vol up+send+power) and nothing. And this is where i need help from the fine people on this forum on what to do next![]()
which do I download to root my phone w/ ver 2.2.2, I tried z4root and for some reason I cant get it to work
it it safe to do this upgrade if ive already installed the 2.2 froyo update
thank you im still ansy about doing the upgrade i just dont want to mess up my phone im not a noob but im always double and triple checking everything (thanks to every one on here for all the help) it a shame the people at metro pcs dont know as much as you guys know now if we can get them to get the 3 g going we will be all set
I am running 2.2. Also from were could I get a better keyboard?
cricket...So today I went into my settings then sdcard update and it started unpacking something and I thought is was 2.2. after my phone rebooted it was all back to my stock settings. I couldnt understand why. However I had a dload update packagein my sd card and im asuming that it reloaded that. So now its back to square1. I wanna flash to whatever is better then 2.1 lol. Anythoughts to what is gonna give me the best performance? 1 of my main concerns is after a year of doing all types of stuff on this phone I have so much stuff in my memory card and I would like to free up the memory but dont kno if theres certain things I will need or can get rid of. Also wil the cm6-cm7 allow you to save to sd? Thanx. if you wanna help me deck out my cell, hit me through my inbox.
