ShinySide
Extreme Android User
You seem to know just a little bit too much about this subject lol. j/k![]()
Why do you think I know how to turn it off? LOL
Why do you think I know how to turn it off? LOL![]()
I have an huawei ascend m860 and I upgraded to 2.2. Since I have done that, my text messaging is not working properly. I. Can send text, pictures but can't receive text messages. Is there something I can do?
Hiya , I finally install 2.2 on my Huawei Ascend
and notice , its different , the 9 screens is gone ?
its 5 now ? and some stuffs from the org 2.1 ascend are gone ?
so i was wondering , am i missing some files ?
or install it wrong ?
I download the 2.2 from metro App from my phone
also , when i had teh 2.1 , I have all the app , like z root , tium bkup , etc
will it work with 2.2 as well ?
Thank you
not working properly? Mind explaining what is working and what isn't?
Since you just upgraded, i'm assuming that maybe something went wrong during the installation, you may need to flash the stock froyo again.
thanks cuz i know some of my app dont work anymoreNo that's how its suppose to be. And yes all that will work except z4root. Use gingerbreak to root
BTW , 2.2 I can use Flash ?
how do i put app in my sd card ?
cuz they are still downloading to my phone
Hiya Every1 ,
when my Huawei was running on 2.1
I had everything , but its been awhile
I forgot what App to use
Mainly cuz there are alot of Junk App on 2.2
like My Extra Keep popping up ,
also My Wi-Fi keep turning off ,
which App do I use to uninstall all the Junk app ?
do i have to root the phone again ?
i know z4 root dont work anymore ,
which app is compatible to z4 root ?
Just wanted to deleted the start up screen ,
junk app like , M studio , Loopt , MyExtras , Virtual Card , Etc
Thank You![]()
On 2.2 use Gingerbreak to root. Then use something like Titanium Backup to freeze or remove bloatware.
Actually the metropcs apps are locked away from titanium backup.
I explain how to get at them in my guide (link is in my signature)
A few people have told me this after I told them Netflix now "supports" all versions. That it starts to play then crashes and takes you back to the movie list. So as far as I know no.
what is it and is there any benefits to using it? I notice GOD with his 9132011 has included the GUI for a2sd by the way thank you GOD for fixing the lights.
back to me question is a2sd is that apps to the sd card or the android OS to sd card if I use it will it make things faster or slower because on broad mem is usually faster than flash mem. but if someone who has used a2sd can answer my long drawn out ??? I wound be grateful.![]()
CanOdope
when partitioning the SD card how many should I create and what size should each partition be also how big should each swap be as of last night I created 1 partition on the sd 500megs and a swap of 100megs thank for your fast response to my last question in the forum.
CanOdope
A 100 mbs of swap?????? Dude dont go over 32. 64 max.
