I just flashed CM7 1.2 with the official MR2 radio installed. Last time I tried CM7 1.1 I couldnt get any 4g signal from the MR1 radio. (Yes I installed the right CM7 at the time.) I had been using tesla coil after trying out CM7 1.1 and from where I am sitting as I write this I would get 3-ish bars of 4g signal with the MR1 radio. With the official MR2 and CM7 1.2, I'm getting 1 bar of 4g strength. However, speedtest.net app still gives me speeds of anywhere between 9 to 19mbps down at 1:30 AM and about 5 up. When I last tested it around this hour, I'd always get a solid 15 down 5 up rather consistently.
So, is there even a problem here?
Is the MR2 radio strength slightly weaker than MR1, resulting in better battery life but weaker signal?
Perhaps the CM7 ROM just reads the signal strength differently than tesla coil?
