I use my phone plenty. Sorry if I don't sit and play games all day? I respond to texts, browse the internet when I'm on the shitter and mess around with new and internet apps I find on AppBrain. Over the last 3 days I've spent well over 18 hours off the wifi because Comcast has been failing at life in my area and my 3G is more stable. The 3G is just very solid in Virginia and isn't constantly fighting to stay connected.
3% over 3 days. That's alot of time..
Actually, that's 3% per day.
That's just how percentages work. They are only meaningful if they are compared to other stats. In this case wifi, cell standby, etc. 3% means 3%. 3% per hour is exactly the same as 3% per week, etc.How do you figure? That is 3% total over that total time period?? So how does that break it down into 24hr periods? No where under battery use does it state per 24hrs.
what a tool!=) Stock 1300mAh battery.
