got the update. Now my phone is totally useless! It is unresoosive and stuck checking satus updates, none of my buttons work...NOTHING! Would't even shut off. Had to do a battery pull, and still doing the same thing. :/
ok, after a half an hour of sh!tting bricks, it's finally working.![]()
It was probably bogged down downloading all your contacts and apps.
+1
Mine does that for a while after updating too, just not to the extent he described i guess.
If there is one thing I dislike about froyo is that it automatically tries to download and install all of your apps after installation of an OS or update.
Montuhotep - I had the same problem initially after I installed the updgrade. I updated LauncherPro and after a few batt pulls it seems to have worked itself out.got the update. Now my phone is totally useless! It is unresoosive and stuck checking satus updates, none of my buttons work...NOTHING! Would't even shut off. Had to do a battery pull, and still doing the same thing. :/
You probably have a back up copy of your settings and apps stored on Google servers. After update or hard reset your phone, you must disable automatic restore of those.Yeah the stupid thing keeps installing apps I've uninstalled.
How do we turn it off?
My brothers wifes nephew knows a girl that has a brother whose boyfriend is a CSR at a Verizon store who said gingerbread will be out 2/2/11.![]()
good one!
It is easy. On the very beginning, when you are just about to sign in into your Google account, just press Menu button and disable it. That is it. Hope this would help.![]()
. Isn't there an option some place else?thats me!!! and the chick is LYING!!!!!
what i said was......
$h!#,,,,i dont remember what i said.............
