Successfully used the one-click root method this morning and have s-off and working root. Aside from possibly flashing to a different ROM, how can I remove the bloatware like blockbuster app and asphalt5?
Just flashed my first ROM. Its the one that is described in my signature. I LOVE IT!!!!!!!!!!!!!! Gingerbread, Sense 2.1, its great!!!
Everything worked out as planned this time around!
Also, glad to hear that you were able to obtain root access.
Matt
Which ROM is it? I'm using the phandroid app and can't see your sig. Did you download from clockwork recovery and have to restore your data?
Thanks, I'm glad your root went well too!
This is a link to the ROM. This ROM gives you HTC Sense 2.16.0.0 and Android 2.3.2 "Gingerbread". I put the .zip folder on the root of my SD card, set the phone to "Charge Only", and then opened up ROM Manager. Once there I chose to install a ROM from the SD card. I picked the file and... BOOM! Right into CWM. It was great! No problems yet. Did the full wipe and installed the ROM. Now I'm rockin' Sense 2.1 and Gingerbread!!!
Matt
Downloading now... Thanks for all your help man!!! Is there free wifi tethering in this ROM?
I have some pictures but ImageShack wont take the files and make URL's out of them to post in this thread...
If you know where I could get this done, please let me know!!! I wanna show off my HTC Sense 2.1 and Gingerbreadness!!!!
Matt
Once you upload the file on imageshack, the 4th link from the top that says forums code, copy and paste that line here and it should show up.
I kinda like this pull down better, I like simple.
CoreDroid 4.9 is my favorite ROM so far. Gingerbread, nice theme, no bloat, HSUPA, tethering, and lightning fast.
I'm going to flash 5.0 tonight. I've tried a lot of them, and nobody is as close to perfect as CoreDroid IMHO.
Let us know how you like it, i was planning on flashing coredroid tomorrow.
