Root One Click Root?
Hashtag
Hey, I've got a question about getting together a one-click root. What would have to be done? Because, with giantpunes method, the three things that happen are 1)Use adb to install mirnova and stuff, 2)activate mirnova by pushing the button on the phone, and 3) pushing the neccessary files and changing permissions with an adb shell. All in all, the amount of cmd prompt lines doesn't exceed like 15. Would it be very difficult to compile something together and make a script that would just automatically run each of the lines? I mean, I'm no expert, but it seems like it wouldn't be that hard. I could be completely wrong though.
Well, making batch files is super easy. I'm sure that wouldn't be very hard at all. It would still run from command prompt, but it would be pretty easy :P
I'll make a batch .bat file. I used to make a bunch of them for doing schoolwork definitions so I have expierience. Slutyman, I'll get back to you when I type one up.
Slutyman, do you already have the WINUSB drivers installed? Almost done with the script, and if you already have those from giantpunes method then we could simplify the testing process
If anybody else is willing to try the script let me know. You will have to have the WINUSB drivers installed. You can find them here in giantpunes post like halfway down the page-http://androidforums.com/elite-all-things-root/586938-root-exploit-easier-rooting-without-having-flash-whole-firmware.html
Okay here's the batch file for anybody that wants to try it. Make sure to unzip it. To run it, extract the oneclickroot file, and double click on it. Where you put the batch file doesn't matter.
But here is what does matter- I am in Kansas city with my grandparents for the week so I don't have any of my adb stuff. aka, I wasn't able to test it so I made it as simple as possible. There are some changes you need to make- 1), your adb stuff needs to be located here "C:\android\platform-tools". If it's not then rename it. 2) Ministro II.apk needs to be renamed to Ministro2.apk to avoid confusion... 3)Ministro2.apk, LG_OE_DiagMode_debug_unaligned.apk, lgoeExploit.exe, and su need to be in the the SAME FOLDER AS ABD! Don't put them in the apks sub-folder.
And you have to already have the WINUSB drivers installed and setup as it is in giantpunes root method. You need to download the lgoeExploit stuff and put it in the adb folder. Find them here- http://androidforums.com/elite-all-...ting-without-having-flash-whole-firmware.html
If anybody does this, please get back to me on if it worked. I'm actually expecting it to not go right the first time just because I've not been able to test it myself.
EDIT:Made a new version of the .bat.
I am working on setting up the usb drivers now, I'll give it a try after I get the drivers. The driver from LG is currently installed but not doing anything.
If I had to guess at what wouldn't work, it would be the cmd promp interpreting the "exit" commands as exiting command prompt instead of exiting the adb shell. That will make the cmd window close out.
Drivers installed, phone charges from my laptop but no USB device activity. I've installed and uninstalled. Giving it a break for now.
Okay, so I installed adb on my grandparents computer. Now, I'm testing the bat file, and it's pretty cool! I just have to click enter and the rest is automatic. Unfortunatly, I've run into a roadblock. at the point where the script runs the command "echo ro.kernel.qemu=1 > /data/local.prop", the cmd prompt spits out a "Line: 404 libusb_open_device_with_vid_pid()".
Does anybody know what that is? Or how I fix that?
I've attached a screenshot of the .bat file in progess. As you can see, you don't have to manually enter any commands :P
I'm also attaching an updated version of the .bat for somebody to look at. The old version was pretty messed up.
That error is spit out by the lgoeExploit program when it can't find a phone connected to your computer that is set in diag mode.
I think I know what's causing that. All of the usb ports on my grandparents computer are used up, so I'm doing adb over wifi. The adb can pick it up but I guess the lgoeExploit can't. It works flawlessly up until that part.
So if somebody else could test the .bat that would be great :)
Here's the stuff for the .bat file
Code:
@echo off
rem first script
echo Hi, this is a test version of one-click giantpune root. Make sure that your adb file, are located here-C:\android\platform-tools. Continue when you make sure it is.
Pause
echo Before you start, get in the application settings in your phone and enable Debug mode, enable installation of non-market apps, and set your phone screen to timeout at like 30 minutes or something. Don't let your phones screen go off.
Pause
echo Okay, we're going to start the rooting process. Double check your shit and continue on when you're ready
Pause
cd C:\android\platform-tools
adb shell "rm /data/img/image.bmp"
adb shell "ln -s /data/local.prop /data/img/image.bmp"
adb shell "ls -l /data/img"
adb shell exit
adb install -r Ministro2.apk
adb install -r LG_OE_DiagMode-debug-unaligned.apk
adb push su /data/local/tmp/su
adb shell "am start -n org.kde.necessitas.example.LG_OE_DiagMode/org.kde.necessitas.origo.QtActivity"
echo Here soon, something wil pop up on your phones screen. If it asks to download some libraries, let it. When it gets done, another thing will pop up that says "Push Me". You need to push it. Continue on when you are ready for me to continue.
Pause
adb shell exit
lgoeExploit.exe
echo Okay, I just ran the exploit. It should have popped up with something like "Exploit was called successfully". If it didn't let me know. If it did, continue.
Pause
adb shell "echo ro.kernel.qemu=1 > /data/local.prop"
adb shell "cat ./data/local.prop"
echo waiiiiiiting
Pause
adb shell exit
adb reboot
echo Your phone will reboot, and be stuck in a boot loop. That's okay, we want that. Unplug and plug back in, then click when you're ready to continue.
adb kill-server
adb start-server
adb shell "mount -o remount,rw /dev/block/mmcblk0p12 /system"
adb shell "cat /data/local/tmp/su > /system/xbin/su"
adb shell "chown 0.0 /system/xbin/su"
adb shell "chmod 6755 /system/xbin/su"
adb shell "mount -o remount,ro /dev/block/mmcblk0p12 /system"
adb shell "rm /data/local/tmp/su"
adb shell "rm /data/local.prop"
adb shell exit
adb reboot
Okay, I bought a usb hub so now I've got the phone plugged in with usb and all that jazz. I run the script, and it works up until the lgoeExploit. it comes out with "libusb_claim_interface(0) failed (-12)"...what does that mean giantpune?
If we can get this down I'll make a GUI for it. I'm 90% that the batch will run right, but my phone just won't connect to the computer right. If somebody with the right setup could test it then that would be perfect.
Giantpune, thanks for putting up with me by the way :P
I'm not sure what "libusb_claim_interface(0) failed (-12)"... means, but that came up for me as well,, and after I changed the drivers a second time, (they didn't change the first time, even though it restarted my computer...) it went away and let me to finish through.
@Rob Did the .bat successfully root your phone? I'm gonna try this as soon as I get my replacement phone activated (my original just stopped turning on, very strange lol). Btw, VM is really awesome about replacing a dead phone as long as it falls under the 1 year manufacturers warranty. It cost me nothing, not even in shipping.
Looking forward to your reply! And great work with the scripting OPs!
I didn't try it this way, as I dont know how that works. I am wondering though, I got a text from virgin mobile that says there will be an update in some days that adds some things and whatnot... will this unroot, or break the phone when this happens?
@Rob Sorry I misunderstood your post, but thanks for the response! And, I just got that same message and I imagine that it would. The youtube link in the text we got didn't seem to show a different version of Android running though, so I'm not sure how extensive the update is. Perhaps its just a mobile ID exclusive app/feature for our phone, in which case it shouldn't affect root (unless they are being tricky and trying to foil our rooting efforts!). Btw, I can't wait to remove all that bloatware...
@giantpune... I have one more question about this root method. According to the .bat instructions and your other post no MSL appears to be needed if I read everything correctly. Is this correct? Please forgive me if this is obviously stated...
Funkmaster-you don't need your MSL for this. Giantpune is a genius and figured out how to do it without.
Everybody- I'm halfway done with the GUI. I'm at a restaurant right now, but ill finish it when I get back tonight. It runs cmd prompt in a hidden window and relays the stuff back to a textbox within the exe window. It has two buttons-exit and root. Its got a progress bar. It's more stable to not use the .bat file and just run the exploits strait from the exe so I'm embedding those into it. If I can, ill put the su file, ministries II apk, lg_dialog apk one, and the lgoeExplpoit into the exe so that you only have to download and mess with one file instead of five.
Really awesome of you to do all this work, and everyone else of course, id test it for ya but as you know i have jcase root successfully done
Lol, its the thought that counts. Hopefully this will make it easier for newcomers to root their phone. I'm still in awe that giantpune was able to completely bypass the msl and root the phone without any outside stuff. It took like 15 of us two or three weeks to get that done.
Okay, I've added the gui as an attachment. The scripting hasn't even been tested by anybody yet, so I didn't add all of the files into this one. You'll need to make sure that all of your files are in the places I've described earlier in this thread. If somebody could test this,even just to check that the scripting is working right, that would be amazing.
EDIT: I put in the progress bar, but there are so many processes that the thing flipped out and just looked annoying. I'm not advanced enough to smooth it out, so I just deleted it.
EDIT: Deleted the attatchment. Made a newer version.
Here is the exe coding, the scripting is in a different section-
Code:
[FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Public[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Class[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]Form1[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] [/SIZE][/FONT]
[/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Private[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]WithEvents[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] MyProcess [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]Process[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Private[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Delegate[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]AppendOutputTextDelegate[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]([/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] text [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]String[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2])[/SIZE][/FONT]
[/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Private[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] Form1_Load([/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] sender [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Object[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2], [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] e [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] System.[/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]EventArgs[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]) [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Handles[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Me[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2].Load[/SIZE][/FONT]
[/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Me[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2].AcceptButton = ExecuteButton[/SIZE][/FONT]
[/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Me[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2].AcceptButton = Button1[/SIZE][/FONT]
[SIZE=2][FONT=Consolas]MyProcess = [/FONT][/SIZE][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]New[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]Process[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]With[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] MyProcess.StartInfo[/SIZE][/FONT]
[SIZE=2][FONT=Consolas].FileName = [/FONT][/SIZE][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515]"CMD.EXE"[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2].UseShellExecute = [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]False[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2].CreateNoWindow = [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]True[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2].RedirectStandardInput = [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]True[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2].RedirectStandardOutput = [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]True[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2].RedirectStandardError = [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]True[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]End[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]With[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]MyProcess.Start()[/SIZE][/FONT]
[SIZE=2][FONT=Consolas]MyProcess.BeginErrorReadLine()[/FONT][/SIZE]
[SIZE=2][FONT=Consolas]MyProcess.BeginOutputReadLine()[/FONT][/SIZE]
[SIZE=2][FONT=Consolas]AppendOutputText([/FONT][/SIZE][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515]"Process Started at: "[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] & MyProcess.StartTime.ToString)[/SIZE][/FONT]
[/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]End[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Private[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] Form1_FormClosing([/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] sender [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Object[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2], [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] e [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] System.Windows.Forms.[/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]FormClosingEventArgs[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]) [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Handles[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Me[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2].FormClosing[/SIZE][/FONT]
[SIZE=2][FONT=Consolas]MyProcess.StandardInput.WriteLine([/FONT][/SIZE][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515]"EXIT"[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]) [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#008000][FONT=Consolas][SIZE=2][COLOR=#008000][FONT=Consolas][SIZE=2][COLOR=#008000]'send an EXIT command to the Command Prompt [/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]MyProcess.StandardInput.Flush()[/SIZE][/FONT]
[SIZE=2][FONT=Consolas]MyProcess.Close()[/FONT][/SIZE]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Private[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] MyProcess_ErrorDataReceived([/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] sender [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Object[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2], [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] e [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] System.Diagnostics.[/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]DataReceivedEventArgs[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]) [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Handles[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] MyProcess.ErrorDataReceived[/SIZE][/FONT]
[SIZE=2][FONT=Consolas]AppendOutputText(vbCrLf & [/FONT][/SIZE][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515]"Error: "[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] & e.Data)[/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Private[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] MyProcess_OutputDataReceived([/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] sender [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Object[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2], [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] e [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] System.Diagnostics.[/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]DataReceivedEventArgs[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]) [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Handles[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] MyProcess.OutputDataReceived[/SIZE][/FONT]
[SIZE=2][FONT=Consolas]AppendOutputText(vbCrLf & e.Data)[/FONT][/SIZE]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Private[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] ExecuteButton_Click([/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] sender [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] System.[/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]Object[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2], [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] e [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] System.[/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]EventArgs[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]) [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Handles[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] ExecuteButton.Click[/SIZE][/FONT]
[SIZE=2][FONT=Consolas]MyProcess.StandardInput.WriteLine(TextBox1.Text)[/FONT][/SIZE]
[SIZE=2][FONT=Consolas]MyProcess.StandardInput.Flush()[/FONT][/SIZE]
[SIZE=2][FONT=Consolas]TextBox1.Text = [/FONT][/SIZE][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515]""[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]End[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Private[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] AppendOutputText([/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] text [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]String[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2])[/SIZE][/FONT]
[/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]If[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] OutputTextBox.InvokeRequired [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Then[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Dim[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] myDelegate [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]New[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]AppendOutputTextDelegate[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]([/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]AddressOf[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] AppendOutputText)[/SIZE][/FONT]
[/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Me[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2].Invoke(myDelegate, text)[/SIZE][/FONT]
[/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Else[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]OutputTextBox.AppendText(text)[/SIZE][/FONT]
[/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]End[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]If[/COLOR][/SIZE][/FONT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Private[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Sub[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] Button1_Click([/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] sender [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] System.[/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]Object[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2], [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]ByVal[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] e [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]As[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] System.[/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af][FONT=Consolas][SIZE=2][COLOR=#2b91af]EventArgs[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2]) [/SIZE][/FONT][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Handles[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][FONT=Consolas][SIZE=2] Button1.Click[/SIZE][/FONT]
[SIZE=2][FONT=Consolas]MyProcess.StandardInput.WriteLine(TextBox3.Text)[/FONT][/SIZE]
[SIZE=2][FONT=Consolas]TextBox3.Text = [/FONT][/SIZE][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515][FONT=Consolas][SIZE=2][COLOR=#a31515]""[/COLOR][/SIZE][/FONT]
[SIZE=2][FONT=Consolas][COLOR=#0000ff]End[/COLOR][/FONT][/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff][FONT=Consolas][SIZE=2][COLOR=#0000ff]Class[/COLOR][/SIZE][/FONT]
now that they are figuring out clockworkmods, how to get into fastboot and bootloader think maybe you can incorporate custom recovery into this soon?
I received a response from LG about my connection issue. They say I need a uSD card to connect the device to my computer... It already has one. Not a clue now.
