Root Oneclick root for 2.2 OTA
imronburgundy
Is there a way to oneclick root for the ota 2.2 yet? I've tried 100 times to do the method on droid life and the droid 2 method but my F#&$!ng windows vista is a piece of crap and I cant get my phone to connect via usb debugging. Plus when I download the sdk, there isn't an installer included to actually install the sdk to my computer. Mahhhh!!! Why can't these developers use Mac software instead of crappy windows?:mad:
try it over and over like i said it took 15 tries i did the same thing every time finally it worked...it just takes like 3 mins total if longer stop it.
I'll keep trying, I tried about 10 times and it only located the device the first time but didn't root after being connected for 30 minutes
Same thing happened to me. It hung. I unplugged the usb from my phone, the dos prompt told me to reconnect. I did and it finished. Finicky! ;)
I'm rooted on OTA 2.2! Weeks ago when I first downloaded android sdk it screwed up my drivers so I had to delete it and reinstall the drivers to get my computer to recognize my phone. This time when I downloaded the sdk my pc was recognizing my phone so I didn't realize it messed up one of the drivers needed for this root process. long story short, a couple hours wasted earlier trying to root then 5 mins tonight after I checked the drivers and reinstalled them
Yeah its in the market. Get the one called Android terminal emulator. It's like a command prompt window. I put a link to instructions in my last post.
Has anyone used terminal emulator to root their DX yet? How did it go any tips? How accurate are the instructions from droidforums?
that's an actual step that is supposed to be done. you can also, instead of just unplugging, pull down the notification bar, click usb connected, and re-select pc mode (or whatever mode you are using).
