what are people running as their max/min? right now i have 691/518. any suggestions to change? Also, what are the different scaling settings/recommended one(s) to use?
for anyone running OC or setcpu, what temperatures are you seeing? Just started running setcpu, and im running near 39C (101-102F). at what point should i be concerned temp wise?
http://androidforums.com/sprint-her...cyanogenmod-6-configurations.html#post1579257What rom are you running, I personally dont run setcpu or oc widget.
I would try to push your phone to 768 if can, if you are having random reboots or other troubles back it back down to 748 and so on...
I have mine set at 768-556
Is that with an unkapped kernel or straight off the ROM?
andygu, hows your battery life at 768?
Just out of curiosity, does anyone know exactly how the Collin Battery Tweak controls battery usage?
