Root "operation not permetted"
cammykool
Android Expert
i get "operation not permetted in PrevailToExistence when trying to root debugging is on sd is out what else?
I have EE14 build, and have tried running oneclickroot dozens of times with no luck. I have the correct drivers installed, KMS4.0, doubleclick the PrevailToExistence.bat when the Samsung logo comes up, but I always end up with mount: Operation not permitted and copying files fails. Ideas?
jus use the odin.. u can use that 2 to install stock with root. very simple 2 do...
DOWNLOAD EE14 ROOTED VERSION WITH CWM AND HROARKERNEL
MEGAUPLOAD - The leading online storage and file delivery service
Here's How 2 Do It...
VIDEO OF USING ODIN
ORIGINAL POST
I too have not been able to reroot with the EE14. I always have to odin. But right now I dont want any mods, kernals, cwm for now. I just want root with EE14. After getting my phone replaced due to constant issues with the phone even after stock flash with odin, my phone started to not boot after a power off. would only show the battery sign. So even with my new phone with EE14 stock the ocr still doesnt work for EE14. I went through my files and found an older ocr which worked for me.
I uploaded it here for those who want to reroot after updating to EE14 without wanting mods.
EDIT: I just uploaded the file here. If that's not ok let me know. Thanks
Ive Tried This Numerous Times After Updating OTA From ED13 To EE14.. Doesnt Seem To Mount Correctly For Me.. It Did Push The Files & I Have SuperUser But I Do Not Think The Permissions Are Correct Or It Maybe Something With The OTA Update That Blocks It.. I Cannot View My Root Directorys @ All & Su Binaries Doesn't Update...
Does the older KMS I added no longer work?
I did just see there was an issue with SU's last update. Maybe thats the issue who knows.
But the KMS in my previous post worked for EE14 rerooting.
tried the new version multiple ways and it would not work. Now with the old version posted I was finally able to root my phone. Thanks so much!!!!!!1111
Yea i was on EE13.. then updated to EE14 Then tried 2 root, & None worked for me @ all. Before the kms i had from interdph used 2 work. so i tried yours, same result...
i believe it was the su's last update like u mentioned though... i just redownloaded the kms from interdph & made some edits to the .bat to get it working again......
KMS 4.0 didn't work for me either. I just tried the default file that MrPeter1985 linked further up in this thread and it worked on the first try!
I put my phone in debug mode. Unmounted and removed my SD card and restarted my phone and once I saw the Samsung logo when my phone was rebooting I pressed a key on my computer when I was at the screen in the cmd prompt that said press any key to continue. (I started the app and was at this point before I restarted my phone.)
Thanks MrPeter1985 you made my day now I can get rid of all these annoying apps.
+1000000000000000000000000000000000000000000000000
FOR those of you having trouble rooting the EE14 versions this worked the first time FLAWLESSLY! thank you so much mr. peter:D
i have followed the steps to the t to get my prevail rooted, the problem im having is, when i try use the PrevailtoExistance.bat file its says that the killing me softly file is missing, it tells me to make sure i unzipped it correctly and i have.
any thoughts?
if you can help email me @ smsjujubean93@gmail.com
Same here. After trying KMS 4.0 four times without success, did it this way and worked like a charm! Thanks!
MRPETER1985 link to the old kms works with works first try for anyone with a crappy precedent.... Thanks for making the short time I have to spend with this phone much more bearable.
