I pulled the source for nothing. Not, I guess you guys get the a full AOSP rom also...
Successfully performed a nandroid backup. Actually pulls the boot.img in it's correct state. Other methods through adb would corrupt the file, but nandroid seems to do it correctly.
How do you know its correct? does it flash back?
@getitnowmarketing what base address are you using when for the recovery and boot images?
Its 0x12200000
beta kernel same disclaimer as recovery.
Supports OC to 864mhz if phone can handle it must use setcpu to clock above 600mhz.
BFQ as I/O scheduler
Added interactive & smartass governors
Added tun.ko, cifs.ko, and support for ext4.
Packaged in koush's anykernel so it will work with virtually and rom as it doesnt overwrite ramdisk.
read notes on overclocking here http://androidforums.com/getitnowmarketing/222328-kernel-thunderc-sprint-optimus-s-oc.html
GNM Optimus M beta kernel
Again if you like my work please toss a donation my way as I don't have this phone.
Will this kernel and recovery be on your git? I also don't have this phone. But thank you for everyone else on here that will use your work in the near future.
Does this recovery use the test-keys?
Kernel flash succeeded and confirmed working with OC. My phone is stable at 825Mhz. Anything higher reboots or freezes the phone. Just curious, but does this kernel do anything like enable stagefright or what not and is it really necessary to have it enabled?
This phone is clocked at 500 from boot, 600/650 would be perfect all around...
So I might as well add this kernel to the Code:Optimus-M modified boot.img
"thunderc")
echo "ondemand" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo 90 > /sys/devices/system/cpu/cpu0/cpufreq/ondemand/up_threshold
echo 30 > /sys/devices/system/cpu/cpu0/cpufreq/ondemand/down_differential
echo 500000 > /sys/devices/system/cpu/cpu0/cpufreq/ondemand/sampling_rate
echo 245760 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
Actually just have them flash this over yours as it will not change the ramdisk you have as its still beta and I'm not done with it yet. Koush's script dumps boot.img replaces kernel and modules and repacks boot.img using existing ramdisk and kernel command line and flashes the new boot.img. Kernel max on boot is set at 600mhz btw to prevent boot loops.
Same as stock it is set to boot on performance gov @ max kernel freq to faster boot and init.qcom.post_boot.sh from stock ramdisk runs to change gov to ondemand and sets kernel min. That is unless you changed this in your ramdisk in your boot.img. The 500000 is the sampling rate for on demand not the cpu_freq.
Code:"thunderc") echo "ondemand" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor echo 90 > /sys/devices/system/cpu/cpu0/cpufreq/ondemand/up_threshold echo 30 > /sys/devices/system/cpu/cpu0/cpufreq/ondemand/down_differential echo 500000 > /sys/devices/system/cpu/cpu0/cpufreq/ondemand/sampling_rate echo 245760 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
Attemped flash for stagefright and got this output:
"E:No signature (7 files)
E:Verification failed"
Yeah, what he said...Zip isnt signed so turn sig verify off in recovery.
