I'm running HydroRom 1.1.0 on my ZHV baseband Optimus S. I've so far attempted to install pDroid on both this rom and the YourMom ROM (by the same team as HydroRom) with no success. pDroid now comes with an executable for windows that allows you to create a special zip for your individual ROM to install before installing the app from the market. Whenever I've attempted to install pDroid I'm unable to make it past the start up flash screen of either ROM.... Has anyone had any success with this?
pDroid is arguable one of the biggest advantages to having a rooted phone. It'd be really unfortunate if i'm unable to get it working. For those of you unfamiliar with it, it's a program that lets you determine which permissions to allow an app that works more efficiently and effectively than something like permissions pro, or similar programs. It's truly one of a kind and FREE.
A simple google for: "XDA [APP] PDroid - The Better Privacy Protection" should provide you with all the info you need (I'm not sure what the rules are about posting links, here).
