If you could add my ROM to this list I would appreciate it!
http://androidforums.com/optimus-s-...-2-11-gb-2-3-3-tuned-perfection-o-c-able.html
ive tried that already i think my phone is hard bricked and i dont how to fix it
No problem. Rooting will open the door for you to get rid of the bloatware. Your available internal storage won't actually increase unless you flash a custom ROM that increases your storage partition.
I'm not sure if you are updated to VC, but I'm going to be putting some more info up on how to root if you've installed the VC update.
Fyi...TR 1.8 for the new ZVD LG update is now available. As far as I know, Sprint has not begun pushing this update yet. If you do want to root or think you may want to in the future, use the LG Updater tool and do it through your computer. Full details and instructions can be found over at Android Central. I updated to ZVD and am running TR 1.8 and it is fantastic!![]()
this thread should be updated.
missing the VD and VH roms
