Hey guys, I'm new to this forum and I searched this forum to find any other previous threads that talks about my problem with my LG Optimus V phone.
None of those threads really helped with my situation so I guess I'll write down my own.
I rooted my phone weeks ago..No problems at all until last night. At night time, my phone shut down on its own and I thought the battery died. I pressed the power button and it turned on, went to the home screen. I noticed that the time went 1 hour behind and the date went back to January 7, 1980.. I was confused and I couldn't find some apps I already installed on my phone like Skype..So, I decided to do a Factory Reset by going to Settings>Privacy>Factory Reset. It went to the LG Logo..and then a "ClockworkMod Recovery v3.2.0.0" screen appeared..It has options of:
-reboot system now
-apply update from sdcard
-wipe data/factory reset
-wipe cache partition
-install zip from sdcard
-backup and restore
-mounts and storage
-advanced
-power off
I pressed on "reboot system now" and it just takes me BACK to that same screen! I pressed "power off" and it turned off..but when I turned it back on again, it took me to that same screen again. I decided to remove the battery, and power it back on..but nope..same screen.
So I went to this forum and searched for people who had this similar problem.
I found this:
Nandroid Instructions:
1) Extract the "BCDS-20110203-0357" file into the "nandroid" folder, under the "mem=477M" subfolder.
1a) For Clockwork Recovery, place the "BCDS-20110203-0357" file in /sdcard/clockworkmod/backup
2) Boot into recovery
3) Go into the "Backup/Restore" menu, and select "Nand Restore"
4) Allow it to restore
5) Reboot! System should be stock
6) Go below and flash stock recovery
Recovery Instructions:
1) Download flash_image and the stock recovery and nandroid back up
2) Extract stock recovery.img and flash_image to the root of your sdcard
3) Open up an adb shell, or terminal emulator on your phone
4) Enter the following codes:
su
mount -o remount,rw -t yaffs2 /dev/block/mtdblock5 /system
cat /sdcard/flash_image > /system/bin/flash_image
chmod 755 /system/bin/flash_image
mount -o remount,ro -t yaffs2 /dev/block/mtdblock5
flash_image recovery /sdcard/recovery.img
reboot recovery
_______________________________________________
I don't have a nandroid folder..nor a mem=477M folder either..
I tried this and it fails. CMD keeps giving me errors and stuff and my phone still hasn't gone out of that annoying ClockworkMod Recovery Screen..I just want my phone back to factory settings like how it used to be when I first bought it. Any help is appreciated. Sorry for this being so long, but I think that the more information/details given, the more chance I can get help. Thanks again.
-reboot system now
-backup and restore
-mounts and storage
-advanced
-power off
I found this:
su
reboot recovery
