D
doggidaddy
Guest
When i use a USB extension cable to add length i cant connect my phone to my pc. The message says it doesn't reconize the device,WHAT. what device its just a cable.
) and there's just not enough signal to make the two connect/talk (properly) outside of a certain distance.Well Sir @scary alien, I am an electrician & you ARE correct. Ac voltage does that too but DC voltage (phones, laptops, USB, ect..) is especially bad about it. [emoji41]Yeah, but the signal (electrons) must travel the length of the cable...
I'm guessing that it's an impedance thing (I'm not an electrical geek, but I think that's the right term[emoji14]) and there's just not enough signal to make the two connect/talk (properly) outside of a certain distance.
Thanks to all . Would a powered usb hub work?As for "what device", the device is the phone, but because of the cable you are using the computer isn't able to communicate with it properly and hence doesn't know what type of device it is.
