Do you recommend us, that want to do the FDR route along side the update, to do the FDR before or after applying the update? Been a while since I did the .905 update on my phone so my memory is vague on how the update is applied OTA.
. I decided that I would apply a .905 FXZ to return to stock,
I thought maybe root was keeping me from successfully updating. Sadly, after booting back into stock, I was could no longer find the ICS update, even through the manual update check
. I received the update notification on Friday October 19th. Unfortunately, after two attempts at applying the update on my rooted phone, I found that I could not apply the update. I decided that I would apply a .905 FXZ to return to stock,
It seems a bit strange to me that no one has yet posted the official .406 OTA for manual update. From what I understand, one has to simply copy the update file from the \cache folder prior to applying the OTA update. Hope someone with a bit of insight can manage this for some of us sooner than later.
This is part of the Moto Blur launcher... you will need to try a different launcher, GO Launcher, Nova, Apex, Holo, or any other number of launchers are available in the Play Store.I do not like the dock software in ICS! Wow, what a difference! Is there a good alternative dock software anyone is aware of? I used to like the productivity screen with the calendar feature and side options... Unrooted, ota ICS...
I like Amazon MP3 because it can group by tracks with each album.
... Thom
It's not the way I look at it but Amazon MP3 select Device select Playlists ...
... Thom
One day I will learn to stop doubting you. LOL. Thanks, Thom.
Yes. Discussed here in other threads. One person reported it went away after a Factory Data Reset.
... Thom
OK. I have an actual issue after the ICS OTA. (No... Not headphones whining. That's not my problem. lol)
Charging. I have been using a non motorola USB charger (Easy... it always worked before lol) and I have been unable to charge past 20% after I was fully ICS'd.
When I get home, I will try the actual Moto charger and cable (USB as well as wall outlet), and also try wall a non Moto wall outlet and see if that makes any difference.
I'll let you know what I find out.
