Rockaholic
Can I get the OTA if I'm deodexed with a custom boot animation?
nope. you need odex files or the update will failCan I get the OTA if I'm deodexed with a custom boot animation?
thats why im sitting here pondering. do i SBF now or wait for zip file.I think you may be incorrect.
)nope. you need odex files or the update will fail
Well, if you're rooted and deOdexed, can't you just make a backup ROM with Koush's Bootstrapper, SBF to new update (if needed), re-root, re-deOdex, then just restore your ROM via Koush's Bootstrapper?
No need to make a backup before you upgrade, it will put you in boot loop if you use old backups. personally its not hard to sbf, OTA update, root and deodex especially with the on click root tools and being able to flash a deodexed theme or Rom, it wasn't all that bad when we had to do that stuff manually. I don't get why anyone who has already been though these processes are making a big deal about.
^ I wonder if you can install just the data portion of an old nandroid backup after upgrading?
Maybe that would work, there is that option in "advanced restore" if it didn't work then a simple sbf and you'd be back up and running
I've wondered about that too.
Install Titanium backup, make a backup and you can restore apps and their settings. I like appbrain to keep track of what I have installed as well. Install appbrain from Market and login at appbrain.com to track and backup your apps.
I'm guessing you mean a backup with titanium backup? if so then yes you can just restore that. If you mean you made a Nandroid backup, then no you can not use that or you will brick your phone.
Here's what I was running:
Rooted
Deodexed - with 928's theme
Removed all Bloatware
Stock OTA Froyo ROM
Here's what I did to get 340:
Re-odexed by using 928's "back to stock" package
(Re-odex restored all the bloatware)
Ran update.zip provided by phandroid
No SBF crap needed, this worked fine and I didn't lose all of my stuff. Now question is, can I use 928's same deodexer package for 340? Does anyone know?
Its a nandroid but I was gonna restore before the update.
Rooted
Stock OTA Froyo ROM
