O.K., this is driving me nuts. I am rooted and running Mirage 07132013 build and ZenGarden 2.0.3.3-T recovery on my OV. My OV has developed a consistent horrible lag. I often try to open apps the OV hangs and I have to do a battery pull. I have re-downloaded and re-flashed mirage multiple times.
I have tried routinely fixing permissions via terminal emulator as well as clearing out all of the caches. I've yet to find any tombstones using ES file explorer.
I keep Fast Reboot, SD Maid, AppCache Cleaner and others ready at hand to clear out RAM, but I should have plenty of ram available, keeping it about 50% free +/-.
I've tried cleaning things up by following tli's advice (which has worked in the past) to me at http://androidforums.com/optimus-v-all-things-root/778987-bad-uninstall.html#post6186387 as well as other cleaning routines recommended in the forum.
Regardless of how I try to keep things cleaned up, within hours my OV bogs down it takes several minutes just to get the phone directory to come up.
Or I go to switch to a different app and the thing just sits there and churns.
Just played the same game with a Handcent text that came in...took me forever to get the app up and running so I could read the txt. The problem does not appear to be limited to just one or two apps...something happens that bogs down the entire phone.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
