aaronmach1
Ive been noticing that ill set my droid overclocked to 1000mhz max and now and then ill notice that it sets itself back to 800mhz max. why does it keep doing this?
yes i have a profile for sleep/standby and one for charging, both set at 550mhz. thats not the issue though. im mean its setting its self and will hold it until i adjust it back to the 1000mhz that i want. not just adjusting itself in standby or charging.Do you have any profiles set within SetCPU? If you had a charging profile set for a lower frequency, your phone would move to that freq as soon as you plugged your phone in. This can also be set via battery power remaining, temperature, etc.
Well i notice it has did it a couple times now.i would say once a week. Im rooted with smoked glass v5. im using set cpu by michael huang. kernal version:2.6.29 smoked_glass adamz@ubuntu #9.Okay, I understand your issue but I need a little more info. What is your current setup (Rom version, Kernel version, SetCPU version)? Has this just started out of the blue, are you using a new ROM, new kernel, new installation of SetCPU??? I'm just trying to get a feel for whether or not this is a new problem with an existing configuration or a problem where it has never worked propertly.
Some things I would try without knowing those details (starting from the easiest to do):
1) Uninstall/Reinstall SetCPU
2) Re-flash your existing kernel
3) Flash a new/different kernel
4) Back up your apps and make a nandroid backup...then wipe your phone (data and cache) and then reinstall your current ROM. Then restore your applications.
ok i figured it out but i dont know why. It does it everytime i shut the phone off and when i turn it back on its at 800 instead of 1000mhz. your right its not a big deal but i just wondered if i could change somthing to remedy it.
figured that one out i must not have, but im trying a new rom now so ill see how it works out!This is probably a dumb question, but do you have "Set on Boot" checked in SetCPU?
As stated above you need to have setcpu "set on boot" checked or it will revert back to what the kernal is set for stock which is 800 on boot up. check the set on boot and you will be fine.
