koopakid08
Android Expert
Can someone give me noob guide to overclocking on rooted stock?
The only way you can oveclock this phone is to install any of the custom Roms,just rooting it will not work,and trying to push the CPU to the max is not advisable, the life of the phone is greatly reduced.
I am also overclocked you just need a custom kernel.The only way you can oveclock this phone is to install any of the custom Roms,just rooting it will not work,and trying to push the CPU to the max is not advisable, the life of the phone is greatly reduced.
Since no one has bricked their phone yet due to OCing, that is purely speculation.![]()
reduced life doesn't mean instabrick
overclocking ALWAYS reduces the life of the hardware but the hardware even when overclocked (within safe overclocking range... obviously OCing an optimus to 1GHz might be a bad idea) will usually outlive it's usefulness... especially with phones
I am running rooted stock and according to Android Assistant my processor is running at 480mhz. I used SetCPU to OC.
I thought it was 200.Technically, your not overclocked. Stock clock speed is 600mhz
How do you know no one has not bricked a V,by overclocking it.
