what percent do you put the "battery" 0%-101%I set battery temp highest, then screen off, then charging...
Gotcha, sorry for the dumb questions, it's just the one thing I don't fully understandYou might want to try just the kernel with its defaults for a bit (one or two charge cycles), then change one thing at a time (overclock, add profiles, etc.). The reason those who are using smartass aren't using profiles is because smartass basically does everything that typical profiles do automatically. Search for the setcpu guide, here, on this forum. It will explain how to setup profiles correctly. Priority basically means "which profile should activate when the conditions for two ore more profiles are met at the same time".
i dont wanna have to use profiles, but at the same time i dont want my phone 1190-1190 all the time....if the screen is off i'd like it to be 245-245...do I have to use profiles to do that? and if so what do I select for the profile name (i.e. charging, charging ac, charging usb, screen off, battery <, temp > etc.)
I linked him the Starter guide from XDA a few posts back. Nice to see you around Akaza.
. XDA seems to be sluggish right now, so the setcpu guide here is a good start.uh oh lol...i was in "manage applications" to uninstall some apps and my phone rebooted, then froze on the loading screen with the burning skull.....
I was uninstalling SetCPU bc I accidently denied superuser permission
2.6.32.27-Netarchy-toastmod-4.3.2-cfs-sbc-havs-less and that's with SetCPU working at 1190 max 245 min (smartass)
