boricuakiller
Android Expert
is overclocking can messed my phone i never overclock this phone and also bateery life after overclock right now i get 17 hours on ld lg 3.3 can some explain the benefits and cons of overclocking
Benefits of oc? Not much. Unless you play games there is no point. Regardless of what anyone. All it does is destroy your battery life. Pro and cons are basically what you would think they would be. If your a normal user and only play basic generic games then your better off under clocking. Way more battery life is saved by uc'ing.
Oc'ing is over rated and is generally bragged about by newbies that think it somehow makes them superior. As if they have something special. Check the devices section up under each person's user name in the forum to see what I mean. Lol. Rather amusing honestly.
Anyway. Yeah. Don't do it. Unless your playing need for speed and its lagging. Then once your done, disk it back down to 700 and enjoy the battery life your saving.
Btw, there is a million and 1 threads on this topic. Utilizing that search function yields faster results and saves from clogging up the forum.![]()
What is a safe number to underclock battery life and also speed do i need to change some number to number 2 o something i dont know just want to make sure i get it right
k aplicacion?Puedes enviarme un mensage yo creo te puedo ayadar con una muy buena aplicacion que siempre uso en mis roms y se aplica cada vez que tu enciendes apagas el telefono osea reboot
