itsthekidbigc
Member
Any developers up to compiling a kernel to reach the maximum of a snapdragon s2? Get working below
You're phone deserves a better owner that respects it. That's all I'm gonna say.
I seem to be the start of this issue I'm really sorry for contributing to a debate I just figured what the hell were stuck on a stock modded or what not type ROM on gingerbread then maybe try to crank up what's already been done. Its really more important to look for a way to tether or maybe get a cm10 build which I believe its bring worked on. I've created a page hoping to get Paypal information as I already owe the developers for their generous work
If you want it that fast, I would tape it to a cheetah's back.![]()
I've tried messing with the kernel myself a bit, using this method: Free Your Android - Extracting, Editing and Re-Packing boot.img in Windows
I can unpack the kernel fine, but when i go to repack it, the file it makes is several MB smaller and won't boot. From my limited knowledge of the process, I believe I need to adjust the command line options when I repack it, but I don't know what they should be.
