Help Overloaded EVO
Refector
Greetings one and all. I just joined as I have a phone question/issue that I hope someone can help with.
Im getting the Phone storage space is low message. I have moved as much to the SD card as I can. The problem is I am "linked" to my work e-mail and its taking up GOBS of space. Is there any way to reduce this without deleting the mail at work? nbecause when I delete it on the phone...it also deletes it on my outlook server at work.
HELP??????
HELP??????
you can change the setting to not delete the mail off of the server. I can't remember if its in the Incoming Server or the Outgoing Server but there should be a check box that is checked saying delete mail from server just uncheck that and it should stop deleting them.
Also FYI moving apps to the sdcard does not move the full app. It only moves data for the app. So you still have large chunks of the applications in your phone memory.
