Root Oxygen Answer Call Sliders wrong way
I've moved to Oxygen 2.2.1 today and everything seems great apart from one strange issue. When I receive a call the sliders are pointing up/down instead of towards the middle of the screen. They still need dragging towards the middle of the screen to work. Is this something specific to the rom or is it just my install? I did do a wipe beforehand. Also any ideas on a fix? Cheers :)
are you able to screenshot it?
i think you can use one like screenshot which has a timer so you can lock it and wake the phone and it should take the screenshot
Image attached
