mattdanielc
Hi guys
I believe the 'Package Installer' is the thing that allows me to install apps?
I've only just noticed it in my 'manage applications' - I'm sure it never used to appear at the top of the list - and I'm tight on memory - so when it takes up 13mb as it does now I'm a bit stuck.
Can I click 'clear data' on it - or will that remove apps? There is no option to clear cache - all 13mb is listed in the Data.
